TephraXMOD V1
Old Apr 29, 2011 | 12:46 AM
  #541
nonschlont's Avatar
just looked at the 55590107 rom and everything looked good, but the "alt. cranking enrichment" is missing a scaling... Im assuming it should be "TimeInjCranking" but when I got to the drop down list, its not there.
and is also missing the Cranking Enrichment IPW Adder (Main)
as always Tephra, You Da Man!!!
Old Apr 29, 2011 | 02:31 AM
  #542
tephra's Avatar
<scaling name="TimeInjCranking" units="ms" toexpr="x*0.005" frexpr="x/0.005" format="%.3f" min="0" max="500" inc="0.005" storagetype="uint16" endian="big"/>
That's been in evo10base.xml for quite a long time...
Not sure why Golden doesn't include it...
Old Apr 29, 2011 | 08:17 AM
  #543
Golden's Avatar
My site has all the addresses, scalings and tables in different MYSQL tables. It merges them all together to form a ROM definition. It only includes the scalings that are needed to define the ROM. I don't have "Cranking Enrichment IPW Adder" defined for that ROM, therefore it does not include the "TimeInjCranking" scaler.
I'll define that table so that the scaler comes along for the ride.
Old Apr 29, 2011 | 08:19 AM
  #544
tephra's Avatar
55590007:
<table name="Cranking Enrichment IPW Adder (Main)" address="5753e">
<table name="Coolant Temperature" address="6124e"/>
</table>
<table name="Cranking Enrichment IPW Adder (Unused)" address="56b48">
</table>
Old Apr 29, 2011 | 08:23 AM
  #545
Golden's Avatar
I added those addresses to the site.
nonschlont - You can get a new copy of 55590006.xml and it will fix the issue.
I really need to fix the Temp thing too. I should make a pull down for Celsius or Fahrenheit.
Old Apr 29, 2011 | 01:55 PM
  #546
nonschlont's Avatar
thanks fellas
Old Apr 29, 2011 | 11:59 PM
  #547
lanasa's Avatar
Beside from your fuel, and timing maps what other ones are beatifically? I am guessing that the Cranking Enrichment and cooling are important too.
Old Apr 30, 2011 | 03:16 AM
  #548
tephra's Avatar
what do you mean cooling?
the maps are a set, meaning fuel+timing+boost = a power level
you get 2 sets, the stock set, and the altmap set.. two power levels or two fuel types or whatever..
Old Apr 30, 2011 | 04:19 AM
  #549
gloom's Avatar
I will donate if you make it happen for the 2010 Aus/EDM Ralliart. Pretty please
Old Apr 30, 2011 | 04:25 AM
  #550
tephra's Avatar
let me know how much...
email me... myforumname at gmail
Old Apr 30, 2011 | 04:35 AM
  #551
gloom's Avatar
There will most likely be more forum users intetested in this but I‘ll mail you about donation.
Old Apr 30, 2011 | 12:37 PM
  #552
KOTT's Avatar
Hi Tephra
i need launch adress for 2008 EDM/AUDM 5MT - 53040110
Old Apr 30, 2011 | 07:09 PM
  #553
tephra's Avatar
Old Apr 30, 2011 | 08:20 PM
  #554
Golden's Avatar
Does he mean these?
<scaling name="Throttle Cap" units="%" toexpr="x/1024*100" frexpr="x/100*1024" format="%.1f" min="0" max="100" inc=".5" storagetype="uint16" endian="big"/>
<table name="1st gear TPS limiter (Drive)" address="60768" category="SST" type="2D" level="2" scaling="Throttle Cap">
<table name="RPM" address="625cc" type="Y Axis" elements="18" scaling="RPM"/>
</table>
<table name="1st gear TPS limiter (Reverse)" address="60792" category="SST" type="2D" level="2" scaling="Throttle Cap">
</table>
Old Apr 30, 2011 | 10:45 PM
  #555
tephra's Avatar
2008 JDM 5MT - 52360018 TephraXMOD is up!
