TephraXMOD V1
Old May 27, 2011 | 07:57 PM
  #601
GTR2009's Avatar
tephramod replaces the low octane maps? or they will still work?
Thanks !
Old May 28, 2011 | 12:58 AM
  #602
Segfault's Avatar
You have to copy your own maps into the tephramod.
Old May 28, 2011 | 12:59 AM
  #603
tephra's Avatar
Thanks !
no stock low octane maps still work, but are used for both altmap and normal map..
Old Jun 7, 2011 | 09:44 AM
  #604
YaroRS's Avatar
guys, I want to use 5 v signal for map switching, what "alternate map master" on the ECU should I use ?
Also, when using Aquamist HSF6 failsafe system, what "alternate map master" should I use ?
Old Jun 8, 2011 | 02:26 AM
  #605
tephra's Avatar
5v switching only works for EDM cars because they don't have the fuel tank pressure.
so you want to wire it into the fuel tank pressure signal - which is pin 112.
try it and it should work, OTHERWISE use the tried/trye method of the resistor method (like the USDM guys have too)
Old Jun 8, 2011 | 02:38 PM
  #606
Richard L's Avatar
Tephra,
Can you remove or replace the aquamist diagram on the first page, I believe the white and the black wire is quite accurate.
The following diagram works well. The 270 ohm resistor is very closed to the trigger point of 0l5V. Can you default it to 0.7V? I can alter the resistor to 200ohm (your original value)
[////img]http://www.aquamist.co.uk/HFS3/EVO/USDM/H3v2-tephra-evoX.gif[/img]
[///img]http://www.aquamist.co.uk/HFS6/EVO/EVOX-HFS6-tephra.gif[/img]
Old Jun 8, 2011 | 03:58 PM
  #607
tephra's Avatar
Done!
Old Jun 8, 2011 | 10:53 PM
  #608
SPN27's Avatar
Is there a chance for 52370024 08 JDM SST?
Old Jun 9, 2011 | 07:39 AM
  #609
YaroRS's Avatar
tried yesterday to tune evo x sst with 53050109 rom. Tried 2 ways of connection.
Orange wire to pin 112. When I switched aquamist on, the dashboard light started flashing, but the car didnt switch to alternate map, it stayed on main map.
Tried connecting to pin 115 with white wire, but the failsafe didnt work. It didnt react to fuel level and signal in the white wire didnt change.
Old Jun 9, 2011 | 08:10 AM
  #610
tephra's Avatar
how did you verify the map didn't switch?
flashing dashboard ICS light usually is a good indicator
Old Jun 9, 2011 | 10:35 AM
  #611
Richard L's Avatar
Try setting M/S trigger voltage to 0.6V. The default is 0.5V.
Some system has reported the aquamist mapswicth voltage is 0.53 volts with a 270 ohm resistor. This means the ECU will not see it.
Alternatively, use a 200 ohm resistor, this will bring the voltage down to ~0.4V. This voltage will ensure the altmap trigger.
I have altered the aquamist/tephra drawing to 200 ohm this morning.
Old Jun 9, 2011 | 11:35 AM
  #612
Richard L's Avatar
Tephra, thanks for updating the wiring diagram.
Old Jun 9, 2011 | 02:24 PM
  #613
YaroRS's Avatar
I had 2 fuel maps, one map for petrol, other for methanol. Logged afr and it was from petrol map, not methanol one, but the light was flashing. That was realy strange.
Old Jun 9, 2011 | 07:17 PM
  #614
tephra's Avatar
an easy way to tell is to set the boost/wgdc to 0 on the altmap.
that you can definiltey tell
Old Jun 11, 2011 | 02:01 PM
  #615
darwin_evo's Avatar
I have an evo x with the aquamist hfs6, using V1 rom.
After connecting pin 115 as described earlier in this thread,
The check engine light is on, showing "fuel temp sensor".
Is it supposed to through a cel?
