TephraXMOD V1
I can tell you all that the answer is 100% "When Tephra is ready and the code is ready"
From past experience I can tell everyone that you don't want this released before either of those is true. I can also tell everyone that asking this question 1000x will not only not make it get here faster - it will make it get here much, much slower.... so lets not start that.
Hello All
I have Ralliart USDM 2009 and have methanol injection DDP 5800. i downloaded Rom TephraXMOD-55590107, is it latest version ROM for RA? Tephra can i ask you to add scalling for methanol to latest ROM for RA cause in my country nobody know about ROM and cant do it
Many thanks
Many thanks
question:
i've been on to psi based for some time now, i'm reverting back to load based due to texas weather changes a lot. just want to confirm, the alt map btel also refers to the bclo on the load boost tables right? many thanks!
paypal sent
btw, for those who are always logging knock voltage, how does it looks like in your logs when it's knocking, is it 0.5-1.0 something like that? trying to decipher if it is phantom knock that i'm having at 5.5k rpms. thanks!
A quick preview of my KnockTPSCut in action:
I have my Knock threshold set at 5 knocksum. It works in conjunction with the KnockCEL Load threshold and timer.
As you can see TPS is locked down to 25% for the duration of the KnockCEL timer... (1 second)
The TPS percentage is customisable as well
you might expect my donation by the end of the week!
