Help: Haltech 3 bar map sensor formula
Old Jul 15, 2010 | 06:59 PM
jdmevo123's Avatar
Hi Guys,
I have recently purchased a haltech 3 bar map sensor and cannot find the formula anywhere, I live in sydney Australia so I know my AP is 14.7 PSI.
All i know is the following from Haltech:
callibration is: 0V = -14.PSI
4.717v = 29PSI
Can someone please help me work out the formula I need to log boost and do v7 PSI based boost control.
Thanks
Dale
Old Jul 15, 2010 | 07:13 PM
RoadSpike's Avatar
Originally Posted by jdmevo123
Hi Guys,
4.717v = 29PSI
Thanks
Dale
Its roughly the same as a jdm 3 bar map sensor then use that as a base and just tweak it as needed with the load column you should be fine that way.
Old Jul 15, 2010 | 07:39 PM
jdmevo123's Avatar
ok I will try that. hopefully I can get it working, the load column is the first 0.xxx digits isnt it? or is it the -14.x?
Old Jul 15, 2010 | 11:02 PM
jdmevo123's Avatar
anyone else have any input?
Old Jul 16, 2010 | 12:13 AM
hediki12's Avatar
https://www.evolutionm.net/forums/ec...equations.html
i still dont understand it but check it out
Old Jul 16, 2010 | 06:10 PM
jdmevo123's Avatar
Hi Guys,
I am really stuck, I have tried the JDM equation and the car only reads -6.4837 continuos.
I also tried the GM equation and the same thing happens. Is there rom mods I need to do to tephra v7? or does someone know the correct formula? I am stuck and would really appreciate a GURU help.
I found this graph that shows the linear line if it helps.
http://hhscott.com/93tmv/3-bar_map.htm
Old Jul 16, 2010 | 06:57 PM
jdmevo123's Avatar
Hey guys,
to get it to zero, i used the JDM formula, removed the -14.5, and checked the value it showed it was out. i got this = 15.67107
so i put the formula below in an it red zero on ignition. I took the car for a drive and checked what boost it reached, I know by my boost guage im on 19/20psi and this showed 19/20psi to. Could this formula be right?
0.19347*x-15.67107
Please let me know if this is right, any guru's would appreciate your input.
Old Jul 17, 2010 | 05:25 PM
jdmevo123's Avatar
really knowone has input??? I just need to know if this is the right formula, or if i even can use it?
Old Jul 19, 2010 | 02:09 AM
RoadSpike's Avatar
Don't be surprised if on the weekends responses are slower :P
Looking at your measured values i came up with something different.
0.1809*x- C whatever air pressure is for you C can be 14 depending on altitude but is normally 14.5.
This formula was made on the assumption that 4.717 = 29psi and 0v = -14psi is actually right.
Its still super close to the formula to the JDM 3 bar if you were getting only a constant number something was wrong with the formula you entered. For example you can't enter a formula like this 1.6x-14.5. This fails in my evoscan because evoscan excepts to see a "*" symbol for multiplication and treats 1.6x as a word so the word equals nothing. however 1.6*x would equal some number. So the corrected way is always use * for the multiplier.
Old Jul 19, 2010 | 02:49 AM
leecavturbo's Avatar
agree with that. i think the x symbol is ignored but shown so we visually get its a multiplication at that point
Old Jul 19, 2010 | 09:09 PM
jdmevo123's Avatar
Thanks Roadspike, I will try this tonight and let you know.
Old Jul 20, 2010 | 10:59 AM
teribble's Avatar
update?
Old Jul 21, 2010 | 03:28 PM
jdmevo123's Avatar
I didnt have time last night, I will be doing tonight and letting you know.
Old Jul 22, 2010 | 03:56 AM
jdmevo123's Avatar
still not working
Hey guys,
Put this in and at idle the car is showing -6 where my boost guage was showing -11 or so. Is this right?
I took a screen shot attached to show the problem.
Attached Thumbnails Help: Haltech 3 bar map sensor formula-jdm-map-not-working.png
Old Jul 22, 2010 | 09:10 AM
RoadSpike's Avatar
Hey guys,
Is your gauge in in/hg for vacuum? If so its really close if nothing else maybe off by .5.
Raceghost
Jun 21, 2016 12:40 PM
Hb55047
Jul 11, 2011 07:47 AM
SeanV
Dec 29, 2009 11:43 AM
Mitsiman
Lancer Engine Management / Tuning Forums
May 12, 2006 10:02 PM
