Check engine light after tial q install??
Old Aug 15, 2010 | 07:28 AM
4doorstreetbike's Avatar
I had a tial original 50 mm bov with the 11 psi spring that I borrowed from a friend of mine well my tial q came In today install went fine but after driving it for 2 miles the check engine light came on does anyone know why this happened??After the install the surge went away and the car idle better too also the valve stays closed at idle so I know I have the right spring.I reset the battery and the check engine light went away but didn't drive it after do you guys think it will return??thanks. p0121 code.
Old Aug 15, 2010 | 08:12 AM
Tuxevo's Avatar
I did a quick search for you, typing in p0121 and these was the results. It seems others have had similar issues when installing tial BOVs. I'm sure your answer lies in here, in fact I know it does, but I'll leave you to find it. The whole teach a man to fish thing.
https://www.evolutionm.net/forums/se...rchid=13597352
Old Aug 15, 2010 | 08:22 AM
thanks does this make sense about having the vacuum line hooked up to the metal vac steam causing the light to trigger??https://www.evolutionm.net/forums/ev...-tial-bov.html
Old Aug 15, 2010 | 08:26 AM
Mine is hooked up similar like this not straight to the manifold and I' am using A 1/4 vacuum hose..But when I put the one step up stiffer spring the light went away if it was the line wouldn't the light come or stay on again?
Old Aug 15, 2010 | 10:15 AM
Old Aug 15, 2010 | 01:14 PM
anyone tumble weeds are flying down the block..
Old Aug 16, 2010 | 05:04 PM
guess it's mystery issue O well .
Mauricio Evo IV
Jan 12, 2017 11:59 AM
eliminator 429
May 12, 2016 11:52 AM
oneslow-evo
May 26, 2015 10:51 AM
5LEEPERISAH23I
Sep 13, 2012 07:27 AM
EVO IXMR
13
May 21, 2011 05:34 PM
