Mapping Evo 7 GT-A
Old Aug 15, 2010 | 08:39 AM
foxbat's Avatar
Mapping Evo 7 GT-A
I need some help in order to be able to re-map an E7 GT-A ecu (automatic). My problem is that the xml file I'm using seems to be incomplete.
First, I'm seeing only 2 fuel tables & 2 ignition tables (high & low octane). From what I heard about the GT-A's ecu, it should contain a different fuel & ignition table for each gear.
Second, the low & high octane tables that I get have identical values! It seems that the Y & X axis in both low & high octane tables have the same addresses!
The following is a link of the rom & xml I'm using: http://www.geekmapped.com/forums/att...1&d=1281569603
Any help would be highly appreciated
Old Aug 15, 2010 | 12:23 PM
GregM's Avatar
Have a look here https://www.evolutionm.net/forums/ec...00010-def.html
grayw's Avatar
I've posted an updated xml on the other thread for you.
Old Aug 16, 2010 | 02:57 AM
foxbat's Avatar
Yes, I got it & all 4 tables look right now.
So, I guess it's not true that the GTa has gear-based fuel/ignition tables?
Many thanks
Old Aug 16, 2010 | 11:45 AM
GregM's Avatar
Strange, I thought it had 8 just like the Airtrek.
Old Aug 16, 2010 | 01:12 PM
foxbat's Avatar
If the airtrek has 8, are they 4 fuel & 4 ignition including both high & low octane?
Old Aug 16, 2010 | 01:21 PM
GregM's Avatar
Yes, thats right, it has:
High Octane for N, 1, 2 gears
Low Octane for N, 1, 2 gears
High Octane for 3, 4, 5 gears
Low Octane for 3, 4, 5 gears
and the same for timing.
Old Aug 16, 2010 | 04:50 PM
foxbat's Avatar
Hmm, what is the size of such rom? Is it 512kb or more?
The GT-A's is 512kb, I'm guessing that 256kb is the actual engine management similar to the E7/8 & the remaining 256 is for gear box control.
Old Aug 16, 2010 | 05:13 PM
GregM's Avatar
Airtrek is 512kb.
domyz
Jul 27, 2022 11:54 AM
simple_lancer
Oct 14, 2020 02:18 AM
Dynotech Tuning
Sep 20, 2016 01:30 PM
WytWun
Nov 12, 2013 04:54 AM
foxbat
Dec 5, 2011 12:45 PM
