Minimum IPW
Old Apr 5, 2021 | 06:30 AM
  #226
Biggiesacks's Avatar
Originally Posted by Lancer_Evo_8
Its possibile that when i change the OEM MAP with OEM Injectors to 0x0009 that the car will not start?
Whats the description for SHLL2 and NOP? I don't understand them
These are changes to processor instructions. The instructions are in hex, 0x4908 tells the processor to shift logic left register 9 by 2. 0x0009 is a no operation instruction that just tells the cpu to increment the program counter without doing anything. Yes it is possible that if your minimum ipw was screwed up it could prevent starting. If the mod has been implemented, you need to be using the modded scaling in your XML for the min ipw table. If not you use the stock scaling.
Old Oct 18, 2025 | 06:25 AM
  #227
Mr EVOX's Avatar
Anyone for 85010005?
tephra
57
Dec 23, 2023 09:14 AM
tephra
27
Nov 9, 2014 06:45 PM
tephra
Jan 24, 2013 12:24 AM
jcsbanks
Apr 23, 2009 07:25 AM
DIDYSIS
Mar 13, 2009 05:56 PM
