Minimum IPW
Ok, I changed it to 1502 address and now it shows 0.020ms. I was expecting to see something like 1.2ms is this correct? When we last tried to tune Gary’s car on the FIC 2150cc the IPW at idle was 1.28 so I figured that needs to go down to something like 1.10ms in the new Minimum IPW field but if it's already .020 then I shouldn't' be hitting a limit anyway right?
The 0.02ms is the stock value Mellon.
Original formula was [value] * 256 / 1000 = ipw min in ms
Now the formula in the rom is [value] * 4 / 1000 = ipw min in ms
So your original value of 5 in the rom is 5 * 4 / 1000 = 0.02ms
yeh so you need to "reset" it to something reasonable..
the algorithm changed but the initial value hasn't, so you need to set that for the new algorithm..
8858xxxx
please check...
<table name="Minimum IPW #1 SHLL2->NOP (0x4908 -> 0x0009)" category="Misc" address="29350" type="1D" scaling="Hex16"/>
<table name="Minimum IPW #2 SHLL2->NOP (0x4908 -> 0x0009)" category="Misc" address="29352" type="1D" scaling="Hex16"/>
<table name="Minimum IPW #3 SHLL->NOP (0x4900 -> 0x0009)" category="Misc" address="29354" type="1D" scaling="Hex16"/>
<scaling name="IPW16:SHLL0" units="ms" toexpr="x*8/1000" frexpr="x*1000/8" format="%.3f" min="0" max="65" inc="0.008" storagetype="uint16" endian="big"/>
<table name="Minimum IPW SHLL0" category="Misc" address="1102" type="1D" scaling="IPW16:SHLL0"/>
please check...
why not just drop fuel pressure from pump controll at idle?(bigger value resistor-lower pump voltage before bypass.... lower injected quantity...
and just use normal or even higher ipw for propper controll , because around minimum ipw of the injector(not ecu) behaviour is eratic
i use standalone ecu(quit oem long time ago because lack of support for jdm roms) and just run pump speed through pwm output but a small change of the resitor get's same result,and car will bypass it after certain rpm, tps ,load so it does not get affected and you get proper idle/ac.....
link for diagram....http://www.roadraceengineering.com/e...elpumpinfo.htm
i had this issue long ago on many cars, and always used bypass,even with simple electromechanical control, but now it's easy with ecu controll.....
just my 2 cents..as it seeems this is taking almost 2 years now and still no adequate solution
whit lower pump flow you can run even bigger injectors
