Minimum IPW
Old Nov 22, 2010 | 04:55 PM
  #136
tephra's Avatar
do you mean 1.024?
you might want to raise this to 1.1 - i doubt injectors that big can drive down reliably below 1.05ish...
that probably why you are getting afr swings..
unless you running OL..
Old Nov 22, 2010 | 06:36 PM
  #137
R/TErnie's Avatar
Originally Posted by JohnBradley
Evo IXs have a minimum IPW of 1.04ms, the 1680s shouldnt be maxing that out. I am pretty sure I have your car set to idle in open loop might want to check that.
I'm certainly not idling in open loop
My plan of attack shall be..
Lock fueling into OL, tune the OL first.
Then enable the CL and adjust the minimum IPW to desired idle quality...
and probably raise my idle targets to just over 1k rpms.
I'd like for the CL to work...but we shall see.
Old Nov 22, 2010 | 09:05 PM
  #138
mrfred's Avatar
I'm looking at the last ROM you sent to me (Oct 31), and it is set to idle in OL.
Old Nov 23, 2010 | 12:13 PM
  #139
R/TErnie's Avatar
ORLY?
I guess I'm misinterpreting the open loop enable maps. Is my mistake in assuming that them being populated with values greater than zero for TPS and greater than 60-80 Load in the 500-1500 rpm region?
My understanding was that both conditions had to be met in order to transition from closed loop fueling to open loop fueling? Not true?
I think my mistake may have been assuming that the pedal is @ 0% when at idle. We all know from the data logs that the pedal is @ 12% when its closed. IIRC table 1 for TPS enable conidtions is populated with 10's (10%) for the 500, 1000, and 1500 rows. 10 < 12
:hammer: I'm sorry Aaron I'll actually work on it here shortly lol. I'm wrong.
  #140
JohnBradley's Avatar
Eric,
I am looking at the last one I flashed and its in open loop? it will be in closed loop above 1000 rpm but for 500 and 1000 (hot idle) its open loop.
Old Nov 23, 2010 | 04:37 PM
  #141
So whats the deal with the latenct being .032 m/sec? Is that a scaling error after you apply the patch? IT didnt seem to get clarified well enough for me.
Aaron
Old Jan 2, 2011 | 11:20 AM
  #142
crewdawg130's Avatar
fast freddy, can we use that patch on 96531706 rom???? with the ID2000. is there anything else to change? thanks
Old Jan 2, 2011 | 12:39 PM
  #143
Fast_Freddie's Avatar
Veteran: Navy
Bobby, I don't see why you couldn't use that patch on the SD rom, as it inherits the 9653 V7 base xml... here are the settings I used to get the car to idle in closed loop at 14.7 with my car on pump gas... it may vary a bit car to car, but I am sure you can figure it out... basically drop the minimum IPW until the STFT stops going haywire and the car still runs good...
Old Jan 2, 2011 | 01:51 PM
  #144
testing right now. thanks. will post results soon
this thing is on e85 but well figure it out.... like always, thanks
Old Jan 2, 2011 | 03:34 PM
  #145
FF you got PM
Old Jan 19, 2011 | 05:17 AM
  #146
EvoLutionized8's Avatar
does anyone have the patch for minimum IPW on ROM 96531706? I used the one provided by Fast Freddy that he gave to Babi (Crewdawg130), but it won't load. I'm still running stupid rich at idle because of it. Any help would be greatly appreciated.
I installed FIC 2150's and running e85 all the time, just FYI
Old Jan 19, 2011 | 07:33 AM
  #147
Veteran: Navy
I sent him my entire base and 9653 xml and it still wouldn't load...
Old Jan 19, 2011 | 07:50 AM
  #148
yea, I tried it again and it still wouldn't install. Not sure what the problem is. And I know you said that it shouldn't matter if its specific to the ROM ID as long as its the 9653 base, but could it be an issue? Just curious since it doesn't seem to want to populate. Thanks Fast Freddie for the help.
Old Feb 10, 2011 | 11:30 PM
  #149
mrfred's Avatar
q for you guys: what is the min ipw step that can be logged in evoscan for the evo 10? for the ap, its 0.256 ms.
Old Feb 10, 2011 | 11:36 PM
  #150
tephra's Avatar
whatever the formula dictates...
Eval = x/1000
so assuming x changes in 1 degree intervals, then 0.001ms would be the minimum step.
0.256 doesn't sound right??
Oh - do you mean the resolution of the IPW rather than the logger resolution?
https://www.evolutionm.net/forums/ev...ion-patch.html
This is the first problem, the standard ECU will only allow jumps of 0.256ms, so you can use 1.024ms or 1.28ms.
