Minimum IPW
Old Aug 24, 2010 | 07:36 AM
  #91
Appauldd's Avatar
Yeah...it does go down in that rpm area at cruise.....mine goes to 1.536.
Old Aug 24, 2010 | 07:42 AM
  #92
tephra's Avatar
^ ve ftw
Old Aug 24, 2010 | 08:07 AM
  #93
Appauldd's Avatar
I spoke with Jens @ JIC about this and he states that the stock value of should suffice in almost all conditions.
His recommendations seem to go more towards voltage stabilization and even higher voltage for the fat low impedance style injectors as a method of stabilization of the injector. More voltage creates a stronger magnetic field inside the injector therefore affecting flow characteristics positively.
For me, I don't need to change anything when it comes to minimum IPW.
Now the ability to have smaller steps between IPW for various rpm/load conditions (i.e. resolution) would certainly prove worth while in the smoothness of drivability. Just a thought.
Old Aug 24, 2010 | 10:01 AM
  #94
03whitegsr's Avatar
True IPW step size is 1usec.
If you are only logging the normal IPW, you'll see a step size of 255usec but that is just because the 2nd byte is being trunicated.
Old Aug 24, 2010 | 10:04 AM
  #95
Appauldd's Avatar
Yep....that is exactly what I see.
Old Aug 24, 2010 | 10:17 AM
  #96
03whitegsr's Avatar
Yeah, actual IPW varies by MUCH less then 255usec. Actual step size may not be 1usec, but it would come down to the actual calculations as it has the capability, at least with the memory variable to go down to 1usec.
If the drivers or injector can reliably do 1usec difference is a whole different topic anyway.
Old Aug 24, 2010 | 04:54 PM
  #97
tephra's Avatar
step size is 8/1000 ms
Old Aug 24, 2010 | 06:14 PM
  #98
old4g63's Avatar
Does anybody know if the standard 1 byte IPW is actual IPW that the injector sees or uncorrected (before latency addition) IPW.
Old Aug 24, 2010 | 06:17 PM
  #99
tephra's Avatar
1) the standard 1 byte is JUST the high byte of the 2byte IPW
2) it's post corrected ie after latency as been added.
Old Aug 24, 2010 | 06:28 PM
  #100
old4g63's Avatar
If thats the case than ID1000's can be ran down to ~0.25ms.
http://www.injectordynamics.com/ID1000.html
ID2000's can be ran down to ~0.5ms.
http://www.injectordynamics.com/ID2000.html
Be sure to reference the *corrected* flow vs IPW charts.
Old Aug 24, 2010 | 06:29 PM
  #101
tephra's Avatar
yes - but look at the deviation graph for sub 1.1ms for the 2000's...
Old Aug 24, 2010 | 06:37 PM
  #102
old4g63's Avatar
The deviation percent looks bad because you are dealing with such a low IPW to begin with. The corrected flow vs IPW looks solid, meaning you will achieve reliable opening at low IPW down to abut ~0.5ms. The fuel trims will sort it out from there.
Old Aug 24, 2010 | 06:48 PM
  #103
old4g63's Avatar
Compare to this:
http://site.titanmotorsports.com/blo...ctor-graph.jpg
We tune around non linearities all the time. Many people non linearize the factory MAF when they take off the stock airbox and put a cone filter on. As long as the IPW is repeatable and reliable (precise) then we can work with it. We don't always have, nor do we need precision (linearity to 0ms). I hope that makes sense?
Old Aug 24, 2010 | 06:49 PM
  #104
Fast_Freddie's Avatar
Veteran: Navy
While that hypothesis may be true on paper, real world testing says otherwise... at 1.04 the high z 2000cc start to sputter a bit...
Old Aug 24, 2010 | 07:08 PM
  #105
old4g63's Avatar
My ID2000's are not sputtering down to 1ms.
