Ultimate Alt Maps
Old Apr 15, 2011 | 09:04 AM
  #106
rrkpitt15's Avatar
Tephra you really do amaze everyone with what you can do all by yourself. Its not like you are working with a team of people for a company. If you need a beta tester, let me know!
Old Apr 15, 2011 | 09:09 AM
  #107
fostytou's Avatar
EvoM Community Team
Originally Posted by razorlab
Peanut butter jelly time!
With a GD baseball bat!
Old Apr 15, 2011 | 06:09 PM
  #108
lanasa's Avatar
You did it once again! The man, the myth, the legend! Well all got to give you props, I know I cant wait to play with it
Old May 10, 2011 | 06:44 AM
  #109
tephra's Avatar
ok so I have begun more work on my TephraXMOD V2.
I plan on implementing a Low/High gear MIVEC Intake AND Exhaust map..
Is that what people are after?
Old May 10, 2011 | 08:12 AM
  #110
fostytou's Avatar
EvoM Community Team
Works for me
Old May 10, 2011 | 08:24 AM
  #111
migs647's Avatar
Yah that'd be sweet! (With '11 support)
Old May 10, 2011 | 01:16 PM
  #112
Clipse3GT's Avatar
That would be most excellent David!
Old May 10, 2011 | 02:02 PM
  #113
Hiboost's Avatar
For larger turbo's living on the edge of compressor surge, it certainly seems more beneficial than a cold and warm mivec map to be able to keep 5th gear happy with milder mivec and leaving 1st-4th more aggressive.
Old May 10, 2011 | 07:17 PM
  #114
tephra's Avatar
well m setup retains the cold map...
its just for the hot map there will also be a low gear hot map...
Old May 12, 2011 | 05:51 AM
  #115
kozmic27's Avatar
If possible, gear based boost that seperates 4th gear from 3rd gear would also be beneficial, perhaps more so even than mivec.
Old May 12, 2011 | 06:03 AM
  #116
tephra's Avatar
what over and above the current high/low gear boost maps?
Old May 12, 2011 | 07:05 AM
  #117
tonyboy's Avatar
just a question tephra, i have meth so the alt map is triggered through resistor adc..how can we switch to the other maps? does each alt map has the config to choose how to trigger it? i'm not sure if i missed it, but as far as i read there's only one in the screenshot in post 1 that has that table to set the trigger..as always thanks!
Old May 12, 2011 | 09:27 AM
  #118
RazorLab's Avatar
? We have that from the factory. Any gear split you want.
Old May 12, 2011 | 09:49 AM
  #119
rrkpitt15's Avatar
Are we going to have to wait 6 months for this to come out once it is available to the AP?
Old May 12, 2011 | 11:13 AM
  #120
fostytou's Avatar
EvoM Community Team
I'm not necessarily making a request, but I always found it incredibly helpful to be able to tune each gear on the IX. That possibly could have played into my 4b11 not venting itself.
I'd definitely rather have a generic WGDC reduction vs TPS and 2d table for each gear than just 2x 3d tables. I loved the temp based WGDC reduction also.
