Ultimate Alt Maps
Old May 12, 2011 | 06:39 PM
  #121
Beeble's Avatar
Originally Posted by kozmic27
If possible, gear based boost that seperates 4th gear from 3rd gear would also be beneficial, perhaps more so even than mivec.
it does that already... rpm/mph crossover.
i think with different mivec and boost maps for 1/2/3 and 4/5/(6) that would about do it for most people?
Old May 12, 2011 | 07:24 PM
  #122
tephra's Avatar
Originally Posted by tonyboy
just a question tephra, i have meth so the alt map is triggered through resistor adc..how can we switch to the other maps? does each alt map has the config to choose how to trigger it? i'm not sure if i missed it, but as far as i read there's only one in the screenshot in post 1 that has that table to set the trigger..as always thanks!
Meth rules all!
meaning when the meth is on/active it will run the meth map...
there is only 1 meth map
when the meth is off (or doesn't exist) then you can switch to whatever map you want...
Old May 12, 2011 | 07:26 PM
  #123
tephra's Avatar
Originally Posted by rrkpitt15
Are we going to have to wait 6 months for this to come out once it is available to the AP?
That depends on Cobb.
Once its done Cobb will have an opportunity to license it.
If they don't want to, then it go straight to the community
If they do license it then you can either get an AP or wait a couple of months
Old May 12, 2011 | 07:50 PM
  #124
rrkpitt15's Avatar
I never was a fan of the AP but i am thinking i might have to buy one now. 6 months is a long time to wait unless somethings "leak" out to the community haha. One could only wish tho.
Old May 12, 2011 | 08:11 PM
  #125
migs647's Avatar
This is the part that bums me out. While I completely understand doing work for Cobb, and them getting the rights to it... I don't understand how your last 8 months work that you have not done for them they have the first rights to.
Oh well, guess that's business. Like you, I'm a software engineer contractor, often there is too much red tape involved with work.
Old May 12, 2011 | 10:18 PM
  #126
tephra's Avatar
Well Cobb are going to be releasing new software soon, which is meant to be a big improvement over the old stuff.
They also wanna get the EvoX stuff sorted out properly, 2011 support, and my stuff in so it should be good for everyone concerned..
Old May 12, 2011 | 10:19 PM
  #127
tephra's Avatar
Well they may not want to license it... In which case it will be available here... as soon as its done
Old May 13, 2011 | 05:59 AM
  #128
tonyboy's Avatar
Meth rules all!
awesome..thanks for the info!
Old May 13, 2011 | 07:12 AM
  #129
rrkpitt15's Avatar
You should tell Cobb how bad this is and how NO ONE will want to use it . Tell them that it was a complete and total waste of time... So the OS community can have it. We all appreciate what you have done for this community and we understand why you want with Cobb
Old May 13, 2011 | 11:54 AM
  #130
RazorLab's Avatar
Tephra does have a PayPal address that, in all honesty, should be used more often....
Old May 13, 2011 | 02:08 PM
  #131
migs647's Avatar
I completely agree. It should have been a requirement, every time a tuner puts tephramaps on a car, the car owner should have had to donate. When I was given tephramaps the first time on my VIII (they had just come out), I didn't realize where they came from and what they were. Once I found out Tephra was on his own, I had to donate.
Old May 13, 2011 | 04:57 PM
  #132
lanasa's Avatar
Boy I cant wait to play with this when its done!
Meth rules all!
Old Jun 24, 2011 | 02:56 AM
  #133
tephra's Avatar
guys - just doing the mivec xover.
should I use the same xover as the boost maps?
ie when the boost routines have determined to use the High Gear maps then the MIVEC system will also use the high gear maps?
can anyone think of a time when you would want the mivec maps to swap at different points to the boost maps?
Old Jun 24, 2011 | 04:48 AM
  #134
Beeble's Avatar
^ yes please!!
Old Jun 24, 2011 | 10:42 AM
  #135
RazorLab's Avatar
For the higher torque SST guys I would want a different xOver between boost and mivec.
I run less boost in 1st and 2nd, and I can see running less mivec in 5th and 6th
