V7 maps and Windows 7. any issues?
Old Nov 16, 2010 | 11:36 AM
kaj's Avatar
kaj
i'm thinking about buying a new laptop. has anyone had any issues with EcuFlash working with Windows7?
i'm also worried about compatibility with EvoScan as well.
Old Nov 16, 2010 | 12:44 PM
vd's Avatar
vd
For me latest versions of Ecuflash and Evoscan both work perfectly with Windows7.
PS Just make sure you edit .xml files for Ecuflash outside of the Program Files folder.
Old Nov 16, 2010 | 12:58 PM
Raptord's Avatar
Works beautifully
Old Nov 16, 2010 | 01:39 PM
kaj's Avatar
kaj
not exactly sure what you mean, but i think i can figure it out. LOL. do you mean to move the xml file to another part of the comp and open/edit/save from there? then move it back?
Old Nov 16, 2010 | 01:42 PM
SyZyGy1394's Avatar
On some installs, evoscan is retarded and hides the logs under a "show compatibility files" section. So technically it won't let you open the logs in another program, like excel. You have to move them first...
Old Nov 16, 2010 | 01:50 PM
kaj's Avatar
kaj
Oh, that. My Vista machine does that. Hides it in the "virtual" folder. I tried changing the save folder, but now Evoscan won't open logs in a graph. Fun.
Old Nov 16, 2010 | 02:23 PM
Raptord's Avatar
Weird, never had that problem.
Old Nov 17, 2010 | 04:57 AM
vd's Avatar
vd
exactly what I meant
as for log files and Evoscan - best way is to select folders for all the Evoscan stuff (saved logs, xml, etc.) somewhere in My Documents so that the folder is not affected by those stupid permissions
Old Nov 17, 2010 | 05:01 AM
lan_evo_mr9's Avatar
I'm having the same issue with any ecuflash above 1.43. It will let me open a V7 bin file, but as soon as I scroll down, it will stop working. Works fine with acd bin files and normal bin files.
Old Nov 17, 2010 | 03:47 PM
kaj's Avatar
kaj
ah. i didn't think of that. i'll try it.
that's weird, but i am worried about that. i don't want to get a nice, shiny laptop and not be able to use my old programs.
Old Nov 17, 2010 | 04:59 PM
Yota Eater's Avatar
Veteran: Air Force
Thumbs up
Laptop - DELL M1210 ('06 model) w/upgrade of 4GB DDR2 667MHz RAM
OS - Windoze 7 Ultimate x64
ECUFlash V1.42.2595
EVOScan V2.6
No problems.
Old Nov 17, 2010 | 08:49 PM
kaj's Avatar
kaj
ECUFlash V1.42.2595
EVOScan V2.6
No problems.
i'm looking at a Dell that comes setup just like that. cool. maybe i'll give it a shot.
thanks, guys.
Old Nov 18, 2010 | 03:36 AM
evoscan's Avatar
Silver Sponsor
EvoScan with v2.8.0005 is best with Windows7.
EvoScan v2.6 was forced into compatibility mode by Windows7 and stored the logs in the virtualstore folder.
EvoScan v2.7.0090 and v2.8.0005 now store the EvoScan logs and settings in the My Documents folder now. which is where Microsoft wants everybody to store their files. Just remember if you log in as someone else on the laptop you won't have the same My Documents folder.
Old Nov 18, 2010 | 05:19 AM
vd's Avatar
vd
Ecuflash typically closes when scrolling down the tables if the definition file is incorrect (misses address, scaling or something else). I usually cure this by checking the definition file and correcting it in the part where Ecuflash closes.
loms@
Sep 11, 2016 11:15 PM
Evo47
Mar 22, 2016 11:56 AM
seventh_rx
Northwest Region
Apr 13, 2011 12:54 AM
SNapz
Sep 25, 2003 08:57 PM
