~10.2:1 timing map help needed.
Old Dec 9, 2010 | 09:02 PM
  #31
mifesto's Avatar
hmmm i do wonder if pumping idle to high teens would be alittle too much timing, but then again i dont idle at 1100-1200rpm. part of loud idling is the rpms so i try to keep it around 900. i tried to go even lower but my mechanic(hardcore dsmer) said theres some negative side to going too low with cams because im washing my piston walls etc etc... i took heed his advice and kept it at 900.... but i digress alittle...
john, do you see any negative by pumping my idle timing from 11-ish to high teens?
Old Dec 10, 2010 | 09:49 AM
  #32
JohnBradley's Avatar
It makes it stable in my opinion, I only adjust it as needed.
aaron
tkklemann
Mar 25, 2008 09:06 AM
DRAG
Aug 21, 2007 11:52 AM
jmoudry
Apr 18, 2007 08:00 PM
David Buschur
49
Mar 22, 2007 07:32 PM
dryad001
13
Apr 24, 2006 05:38 PM
