Speed Density 2.0 (3D VE Tables, Baro)
Old Oct 13, 2012 | 04:32 PM
  #511
BoostBaby's Avatar
Well I double checked the afr and timing and they're pretty much the same...I'm going to do another boost leak test just to make sure.
Old Nov 11, 2012 | 04:54 PM
  #512
211Ratsbud's Avatar
Hey guys I'm in a bit of a sticky spot. My map volts : kpa tables won't stay 1:1 if I change the scaling to omni 4 bar. I thought this was supposed to be 1:1 no matter what.
Old Nov 11, 2012 | 05:12 PM
  #513
211Ratsbud's Avatar
Okk, figured it out. For some reason the mapv:KPA scaling got screwed up even though I was still listed as an omni 4 bar. Then I went to copy the map v to kpa column to make it 1:1 and it reverted the map back to kpaomni3bar. I didnt catch that it flipped the scaling down by making it 1:1. So I had to change the scaling to 4bar, then make it 1:1. I dont quite get why it made these changes automatically or what, but I think I got it sorted now. Just seemed really odd since Ive been runing the same rom for a little over a month now.
Old Nov 11, 2012 | 05:14 PM
  #514
211Ratsbud's Avatar
wrong *delete*
Old Nov 14, 2012 | 04:35 AM
  #515
newpassport's Avatar
https://www.evolutionm.net/forums/at...d-88592715.zip
how to use this zip file.just 2kb.
Old Dec 23, 2012 | 11:57 AM
  #516
CDrinkH2O's Avatar
Originally Posted by 211ratsbud
This is how I have accomplished my 3dsd tune. My fuel map reads my desired AFR, while I move the VE to the number that allows me to reach that desired VE. There is a little setup required, but this is easier than MAF tuning for me.
Hey ratsbud,
When you used this approach, what did you set your MAF Comp table to? Was it set to 100 across all MAF Hz?
Old Dec 23, 2012 | 12:29 PM
  #517
211Ratsbud's Avatar
No, I am finally learning how to adjust the MAF comp table. Until last week I never scaled my injectors and dealt with funky fuel trims. Finally I was on a kick to learn something...
So I made my fuel map to what i desired for AFR in the past and just adjusted VE to get my desired... recently I had to adjust VE to lower the Hz at idle slightly(Closed loop), and use MAF comp to the scaling to get the trims reasonable.
johnbradley pointed out that you need to adjust VE according to your STFT in closed loop. So that was[am currently] how I tackled it and if you see the STFT - you need to take VE out and if its + you need to add fuel at that MAP/RPM. I have been trying to disable LTFT so that I can drive and not have LTFT interfere while adjusting the VE to get the CL portion working right.
I still may infact be doing it wrong.
Jamie @ Dynotech has pointed out a very useful way to use your MAF sensor to create a 3d VE map for you. Funny thing is, thats so easy everyone over looks it! So I dont have a MAF sensor right now that I can use for this, because mine is gutted and my exhaust has a few leaks that I need to wrap up. But if you venture in one of the two threads that I just started below you will see his post which ... will eventually be the way which i will try.
My current plan of attack is just get things close enough to give my ANTI-LAG solution a try using factory components then based on the sucess or failure of that, continue to refine my SD tune by using a MAF or maybe not.
Originally Posted by Dynotech Tuning
I would buy another or borrow one for a day.
Here is a simple way of explaining VE (there is more to it than this really). 100% VE means, at 100kpa with 100%VE, the engine assumes that 100KPA=100load. This means that the cylinders COMPLETELY suck in & push out their total volume of air and the ECU sends enough fuel to match. Due to turbulance and poor airflow at certain RPM and engine loads, 100% VE isn't always the case.
Lets use idle as an example. Most cars will idle at 40-65kpa. Lets use a stock Evo that pulls around -18 to -19inHG at idle (around 40KPA) and the maf reading shows a load of 30.
VE can be calculated by using this formula:
LOAD/KPA*100
30/40*100= 75% VE
This means at that particular KPA and RPM the cylinders are only sucking in/pushing out roughly 75% of their capacity and the ECU should only give 75% of the fuel to match.
Now lets use a big cam that has less vacuum. With the MAF installed, you may see -12inHG of vacuum at idle (about 60kpa) and a MAF calculated load of 33.
LOAD/KPA*100=VE
30/60*100= 50% VE
You can log VE in evoscan by using a formula similar to the one below while using your MAF:
([load1B]/[JDMMAPkpa])*100
After logging, you can use your averages in each KPA/RPM area to determine the MAF calculated VE. The more data you get for each cell, the more accurate your VE table will be.
Most evos I have seen have a VE of roughly 80% in the 2000-3000rpm/40-80KPA range for average highway cruising.
-Jamie
Old Dec 23, 2012 | 01:56 PM
  #518
CDrinkH2O's Avatar
I'm transitioning from a fully developed MAF tune to 3D SD. This means that my AFR, boost, timing, injector size and latency, MAF Size and Comp are all perfect for my current build. Most of the past two months in fact was spent tuning MAF Comp from idle to cruise, to get STFT under control. Let me know if I can help you here.
I have good MAF load vs kPa data from evoscan so I can set the starting point for 3D VE. There are a few of important questions that I have not found answers to:
1. Should kPa2Load be left at 1:1 if using a 3D VE map built from my MAF tune? (I would have thought that this could keep AFRs too lean and timing too advanced at full boost, since my actual load (310) exceeds kPa (280). )
2. Should MAF Scaling and MAF Compensation tables be copied over from to 3D SD tune?
3. Should kPa2Load be set based on data from MAF tune (see below for my setup - big cams)?
Old Dec 23, 2012 | 02:10 PM
  #519
Dynotech Tuning's Avatar
Yes, with a 3D table, the kpa2load should be 1:1 with the proper map sensor scaling selected. MAF scaling and comp should be copied over.
The VE table should be adjusted based on the MAF data first. The kpa2load table is just used to tweak certain KPA areas.
-Jamie
Old Dec 23, 2012 | 02:11 PM
  #520
211Ratsbud's Avatar
Good point the kpa to load should be used to line up your load points after you copy your maf tables over then use ve merely to tweak the fuel is how I comprehend it.
Old Dec 23, 2012 | 02:53 PM
  #521
CDrinkH2O's Avatar
-Jamie
Thanks for clarifying Jamie. I was applying the correction to the kPa2Load as well as using the 3D VE map from my MAF tune logs. This effectively applied the corrections twice, and it explains why I couldn't get it to climb out of cruise into boost with out going really lean.
Old Dec 23, 2012 | 02:54 PM
  #522
Best way to do it is to set the kpa2load as 1:1 and use 3D SD and build a map with your MAF.
Old Dec 23, 2012 | 04:01 PM
  #523
211Ratsbud's Avatar
cdrinkh2o did you maf tune your car so that afr map = desired ?
Old Dec 23, 2012 | 05:39 PM
  #524
CDrinkH2O's Avatar
No that is way to Quixotic a project for me .
AFRMAP is just a number to be dialled up or down to set actual AFR where I want it in open loop boost. In closed loop idle or cruise I have used MAF Comp to get mid and low trims in line. I did this by logging MAF Hz and AFR%Error = ([WBO2]-[AFRMAP])*100/[AFRMAP], then adding or subtracting the AFR%Error to MAF Comp at the correct Hz band.
If you are doing this from scratch it's probably easier to use ziad's LiveMap version with autotune to get AFR's tuned quickly.
Old Dec 23, 2012 | 06:02 PM
  #525
211Ratsbud's Avatar
I'm working on getting a 1.3 cable to live map. I guess in the end it there is more than one way to accomplish this goal. I really just want my trims to be excellent.
My midrange ve is around 80 like dyno tech suggested and my low range ve is 68 at idle. I'm going to force open loop above 3500 anyways where my sas will be active to get the alternate map to enrich enough.
I've never seen much more described about sd tuning than what's in the 2d threads as far as maf modeling vs sd. It's nice to see that there is a methodology
Not sure how injector scaling can be accomplished with so many adjustments lol
