Speed Density 2.0 (3D VE Tables, Baro)
Old Mar 2, 2011 | 01:08 PM
  #121
RoadSpike's Avatar
Originally Posted by lan_evo_mr9
I must be doing something stupid or missing something, but I just Dl'd the 885 variant and I don't see any of the 3d tuning tables. The 3d index and lookup tables are present, but under the 'speed density tuning' table, I only have 2d tables which aren't giving me the correct scalings and such.
Right since my work is an extension of the other roms it assumes you have the rest of the xmls from the previous roms. Here's a link to them.
http://www.norcalmotorsports.org/use...OD-XMLPack.zip
Old Mar 2, 2011 | 01:11 PM
  #122
lan_evo_mr9's Avatar
Ok, cool. I was running the r3compile version, so I guess I need to specifically run those in order for this to work correctly? And then just add my own little specific xml extensions that I have.
Old Mar 2, 2011 | 01:12 PM
  #123
RoadSpike's Avatar
Yep that should work.
Old Mar 2, 2011 | 01:24 PM
  #124
That worked, thank you very much.
Old Mar 2, 2011 | 05:45 PM
  #125
VGergo's Avatar
very cool rom I would try the 9653 with 4 omni map. With the base volt map and map kpa table and the omni 4 bar map only need to tune the 3d ve table ? Or suggested to change the values in the map load table too ? 2.0 liter evo9 turbo engine with hks 264cams
Old Mar 2, 2011 | 07:05 PM
  #126
drifterific's Avatar
RoadSpike
I loaded the rom today and the car idled great a little lean but really good still and it drives great. The only thing that I am noticing is that during cruise there is a slight stutter. It is not consistent but it happens frequently enough to notice. This happens at freeway speeds and also during in town cruise speeds. I haven't started to make all of the adjustments yet but I thought I would ask about it
Old Mar 2, 2011 | 07:06 PM
  #127
RoadSpike's Avatar
Originally Posted by drifterific
RoadSpike
Did you try the stutter fixes in the rom?
Old Mar 2, 2011 | 07:52 PM
  #128
Yeah I added that fix. I may need to make some more adjustment in the tune. Its pretty stock from how you created it. I'll dig around the rom some more.
Old Mar 2, 2011 | 07:57 PM
  #129
RoadSpike's Avatar
Any insights as to what conditions cause the stutter will help me find out whats happening too.
Old Mar 2, 2011 | 08:14 PM
  #130
3gEclipseTurbo's Avatar
between 2k-2.5k slight throttle maybe 25-30%.
Old Mar 2, 2011 | 08:19 PM
  #131
RoadSpike's Avatar
That sounds very similiar to the conditions in the original stutter problems hmm.
Old Mar 2, 2011 | 09:06 PM
  #132
I concur with 3gEclipseTurbo, I had the GF tell me what my throttle percentage was when i was at cruise but mine will happen between 2-3k and isn't speed dependent.
Old Mar 2, 2011 | 09:09 PM
  #133
It did happen at 2.6k one time. It seems just like the original Stutter problem but the fix options dont work for it.
Emailed you btw RoadSpike
Old Mar 2, 2011 | 09:31 PM
  #134
RoadSpike's Avatar
I'll see what i can do about it may take awhile to find the culprit though
Old Mar 2, 2011 | 10:34 PM
  #135
RoadSpike's Avatar
About the stutter thing I found this table which is implemented to modify the load when the rpm is above 2000rpm and it has two very odd entries in it. At the end at loads 140-160 it totally cuts out the fuel.
