EcuFlash - X and Y axis values getting mixed up
Old Mar 30, 2011 | 11:13 AM
speedway's Avatar
Hi everyone !
At the beginning I want say that I'm a NEWBIE to the forum and tuning itself !!! So if there was a thread like this one before please send me a link cause I couldn't find one.
I'm trying edit my ignition map to make it more precise and to show values on RPM axis from 0 to 10 000 in 300-350RPM increments and values on LOAD axis from 0 to 290 in increments of 10 but for some reason (and that's the part I don't understand) when I'm trying to interpolate values on Load axis from 0 to 290 values on RPM axis above 8200 (26th element from the top) are getting changed into some numbers like 0, 125, 250, 375 and so on (increments of 125). Same starnge thing is happening when I interpolate Load axis values from 0 to 290.
I attached 2 pictures to better explain the situation
How can I change that or avoid changing those values by Ecuflash itself ?
ECU Gurus please help !
Attached Thumbnails EcuFlash - X and Y axis values getting mixed up-ignition-map-1.jpg   EcuFlash - X and Y axis values getting mixed up-ignition-map-2.jpg
Old Mar 30, 2011 | 11:25 AM
RoadSpike's Avatar
What rom ID are you using it seems like your axis's are not correctly defined.
Old Mar 30, 2011 | 11:32 AM
speedway's Avatar
88590015
Old Mar 30, 2011 | 11:35 AM
RoadSpike's Avatar
Stock, v5, mrfred mods?
Old Mar 30, 2011 | 11:37 AM
speedway's Avatar
Bone stock
Old Mar 30, 2011 | 11:46 AM
speedway's Avatar
I just pulled up a different map I had on my laptop from EVO 8 ROM ID: 96940011 to test it and it does the same thing
Old Mar 30, 2011 | 11:48 AM
RoadSpike's Avatar
Are you changing these map's sizes because to me they look far too big to be stock.
Old Mar 30, 2011 | 11:51 AM
speedway's Avatar
Yup, I added few elements to each axis to be more precise
Old Mar 30, 2011 | 11:56 AM
RoadSpike's Avatar
*facepalms*
You just can't add elements to a table the rom is like a giant sliding puzzle you end up overwriting elements on some other table when you do that. As programmers we have created large maps by moving them into some freespace in the rom but the stock location doesn't have any room to do so.
This is besides the coding changes required for the rom even to recognize the larger map correctly. Put yourself back to stock sizes if you want to use your existing rom or download a large maps v7 tephra version if your set on big maps.
Old Mar 30, 2011 | 12:05 PM
speedway's Avatar
I guess that's the reason why "r3compile" erased one of the rows from the ignition table and put a different one in the same spot without making the map bigger in his video. Thanks A LOT RoadSpike
Old Mar 30, 2011 | 01:15 PM
RoadSpike's Avatar
Sorry to burst the bubble on that idea i wish making big maps was that easy
tephra
70
Jul 11, 2024 12:59 AM
Jack_of_Trades
Sep 22, 2010 08:12 PM
Creamo3
Aug 29, 2008 11:30 AM
vroomevo
Oct 28, 2007 09:23 PM
Evo442
Sep 15, 2007 10:15 PM
