anti-lag set-up help
Old Apr 2, 2011 | 12:16 PM
spooldursti's Avatar
I just received my tactrix cable 1.3u the other day and I'm just messing with it right now trying to figure things out. I want to set up my anti-lag(start) but when i click on it, this box comes up and says "units" 2500. I cant change anything on it though. I found out if I hit the equals button another window opens and says enter a value or expression, D=(blank)
Is that where I input say 4,000 rpm?? Any help is appreciated!
Old Apr 3, 2011 | 06:48 PM
bump.
Old Apr 3, 2011 | 06:53 PM
escodotcarter's Avatar
pretty sure US evos dont have anti-lag (ignition cut). but you can mess with the stationary rev limit which is the launch control (fuel cut)
Old Apr 4, 2011 | 06:19 AM
Well that would explain it then. I never even thought about that. I'll give that a shot on my lunch break and see what happens
Old Apr 4, 2011 | 03:54 PM
Well I tried just a stationary rev-limit and I cant adjust it either. Am I doing this right? All I do is hit, read from ecu, then it loads, and I click on limits, then rev-limits and a box comes up that says I believe 7906 and I click on it and it turns blue, but i cant enter another number? Any input on whats going on here?
Old Apr 4, 2011 | 04:00 PM
there should be 3 options.
Speed limit
Rev limit
Stationary rev limit-----------check this box, hit equals sign = , enter the rpm you want and hit enter.
save the rom and flash it back onto your car.
Old Apr 4, 2011 | 08:14 PM
evoRS06's Avatar
Read the sticky at the top of forums, it will tell you everything u need to know for the basics
Old Apr 5, 2011 | 06:07 AM
Speed limit
Rev limit
Thank you I got it to work now. So what are the cars using that have the real aggresive 2-step sound? Is it through ecuflash or is it an aftermarket say MSD or something?
Old Apr 5, 2011 | 06:23 AM
I dont know and if you dont i would stay away from trying to achieve that because that has disaster written all over it. good luck
Old Apr 5, 2011 | 06:36 AM
evoRS06's Avatar
There is a pretty good thread going on with people fine tuning the launch maps. U should check it out! I just sat down last night and read through it again, and there is some very good info in there.
Old Apr 5, 2011 | 07:04 AM
Yea I planned on staying away just was curious
Which one might that be?
Old Apr 5, 2011 | 09:56 AM
evoRS06's Avatar
https://www.evolutionm.net/forums/ec...unch-maps.html
tunermt
Sep 21, 2024 01:43 AM
Boostin4g63
25
Feb 15, 2010 08:22 AM
Whoop_ass
Oct 25, 2007 01:13 PM
ghoonk
Sep 27, 2007 08:18 AM
xLaNcErEvOx
Jan 31, 2007 11:00 PM
