Need some help with regards to AYC/ACD/ABS ECU
Old Apr 23, 2011 | 01:28 PM
rolly1818's Avatar
Registered User
Guys,
I need some help with the AYC/ACD and ABS ECU. Here is the problem, when I connect to the car using Evoscan 2.5 the EFI ECU works perfectly, I can datalog and toggle on and off the fans etc.
However, whenever I try to connect to the AYC/ACD ECU and ABS ECU is says no response from the ECU. Questions:
1. I have a 1.3 cable I believe its the 1.3U cable, can this work?
Reason I am need this to work is to bleed the AYC lines off the pump. The car is a JDM EVO IX. Thanks in advance.
Old Apr 23, 2011 | 01:44 PM
donner's Avatar
Update your evoscan to version 2.7 (or 2.8), AYC/ACD actuators are not working in earlier versions.
Old Apr 23, 2011 | 01:46 PM
rolly1818's Avatar
Registered User
Tried that still no luck
Old Apr 23, 2011 | 01:53 PM
donner's Avatar
That's strange, I have used 2.8 to bleed my system. Have you selected ACD ecu when tried to operate actuators?
Old Apr 23, 2011 | 01:56 PM
rolly1818's Avatar
Registered User
Oh damn! It doesn't work me should the cable work just fine?
Old Apr 23, 2011 | 02:02 PM
donner's Avatar
Yes, I have used 1.3u cable succesfully with 2.8 (and also with 2.7). Remember to select ACD ecu when operating actuators (also AYC actuators use this selection).
Old Apr 23, 2011 | 02:04 PM
rolly1818's Avatar
Registered User
Ok I will try again, while your at it do you have any good data on bleeding the ayc system? I also tried the manual method and the pump never came on!
Old Apr 23, 2011 | 02:34 PM
donner's Avatar
Old Apr 25, 2011 | 12:48 AM
rolly1818's Avatar
Registered User
i will be trying this tomorrow.
anyone have any write ups on how to do this the manual way?
i tried this and the pump never came on
Old Apr 25, 2011 | 05:43 AM
jimmy79's Avatar
try this:
How to get Mitsubishi AYC/ABS support from an OpenPort 1.3U cable.
Step 1) Pin1 must be linked to pin15.
Early OpenPort cables did not have Pin15 linked to pin1(check with a multimeter continuity test) to see if its connected.
a) No pin1 on the OpenPort cable. Move pin1 on the vehicle side to the pin15 position.
b) Pin1 is connected to Pin4/5 on the OpenPort cable. Move pin1 on the vehicle side to the pin15 position.
c) Pin1 is connected to Pin15 on the OpenPort cable. Cable is AYC/ABS ready.
This worked for me. i also had to use version 2.7 it wouldnt connect with the earlier versions. im using a tactrix 1.3 cable, i swapped the pins around on the car obd port instead of hacking my cable up.
Pref7
22
Jan 6, 2023 04:18 PM
ahmedshaikhani
Aug 24, 2021 10:24 PM
tephra
Oct 3, 2017 08:09 AM
Evo_AK
16
Sep 28, 2015 12:26 PM
electrasol99
Aug 28, 2013 11:12 AM
