'03 evo 8 - ecuflash timeout error
Old May 12, 2011 | 06:16 PM
chaotichoax's Avatar
Can anyone help me here?
I followed all the steps...tried searching for a similar problem...some people with windows 7 had the same issues but unrelated
I uninstalled and reinstalled the newest ecuflash and my tactrix cable is brand new 2.0 rev E
Anyone?
Old May 13, 2011 | 07:42 AM
tephra's Avatar
are you using the white connector as well?
Old May 13, 2011 | 03:14 PM
yes I am...I plugged in the tactrix then the white connector...then turned the key to on
Old May 13, 2011 | 06:51 PM
anybody?
Old May 13, 2011 | 07:39 PM
tephra's Avatar
enough volts in the car?
that pesky fuse that stops you reflashing ok?
otherwise it looks like a driver issue to me... uninstall ecuflash, uninstall ALL the openport drivers..
maybe install the beta 3000 (or was it 3150)...
Old May 13, 2011 | 10:58 PM
car was freshly driven
what is the fuse you speak of?
I didn't manually uninstall the drivers...what is the easiest way to uninstall them?
Old May 14, 2011 | 01:43 AM
tephra's Avatar
in add/remove programs if you see any tactric/openport references then uninstall them (after you have uninstalled ecuflash that is)
i cant remember the fuse exactly, search on here.. some guy couldn't reflash or something and he found a fuse was blown...
Old May 15, 2011 | 11:36 AM
removed ecuflash and the individual taxtrix drivers that were installed...still doesn't work
I tried evoscan for the hell of it...evoscan doesn't recognize the cable either...I'm starting to think maybe the cable is bad
Old May 15, 2011 | 08:05 PM
tephra's Avatar
hrmm could be...
did u try the beta ecuflash? 3150?
Old May 15, 2011 | 10:26 PM
I did not, where can I download the beta from?
tephra's Avatar
tactrix.com -> downloads -> beta software
Old Jun 7, 2011 | 09:36 AM
safat_evo's Avatar
same problem with me bt my 1 is 1.3u cable.what should i do??please help me out
Old Jun 19, 2011 | 09:39 PM
Resolution Update:
After conversing with John @ Akuma, he determined it was the smaller white "writing" plug that was causing my connection issue.
I sent my cable back to tactrix for a replacement and received a new cable. I was able to read and write to the ECU.
Thanks to John @ Akuma and Amanda @ Tactrix for helping me resolve this issue.
mymigi
Jul 25, 2019 03:34 AM
nismo3183
Nov 26, 2012 07:51 AM
MrHouse
Oct 5, 2010 10:27 PM
HOSTILE_EVO
Feb 11, 2008 11:47 AM
