Won't take timing up top Help!!
Old May 15, 2011 | 06:20 PM
fugiwara's Avatar
Lightbulb Won't take timing up top Help!!
I've compare my timing map with many other tuned evo and my timing is much less up top.
I know every car is different, but I want to make sure this is normal.
Boost leak test was done prior to the tune.
EVO8 6 sp
HKS 274/278 cams
HKS 7460R turbo
850cc injector
Full TBE
ETS IC
tephra V7 94170715
Grimmspeed 3 port solenoid
JDM map sensor
255 fuel pump
Old May 15, 2011 | 06:31 PM
RazorLab's Avatar
Are you not running more then 240 load?
You load curve would be helpful. Without that we can only guess you are either running pretty normal timing (240load and below) or horrible timing (260 and above)
Old May 15, 2011 | 06:42 PM
fugiwara's Avatar
I am gonna look for it now, in case I can't find it, can you tell me what its called?
Old May 15, 2011 | 08:11 PM
fugiwara's Avatar
where to find load curve? i want to post it up.
Old May 15, 2011 | 08:16 PM
Raptord's Avatar
We just want to know how much load you are seeing throughout a pull so we know what cells you're hitting. Post a log or a maptrace.
Old May 18, 2011 | 09:27 AM
bambooi's Avatar
How much boost are you running at high rpms? That plays into the equation as well.
Old May 18, 2011 | 10:04 AM
ranz's Avatar
boost and load your hitting will be helpful.
Old May 18, 2011 | 08:17 PM
C130flyer's Avatar
Dude if you don't already know where to find you load curve then you shouldn't be tuning your own car yet.
FYI you should be logging load when you datalog the car, there are a few different loads you can look at there is Loadcalc, 1byteload, 2byteload etc etc
Post up your evoscan datalog file and we can help you
Do you have a wideband? What AFR are you at after spool up to redline.
How much boost are you running?
What type of gasoline (reg, premium, e85, racegas etc etc)????
740 Turbo Brick
May 29, 2022 06:47 PM
j255c
For Sale - Cars For Sale
39
Apr 17, 2016 07:52 PM
TTP Engineering
Evo X Dyno Results
31
Oct 26, 2009 02:27 PM
TTP Engineering
Sep 3, 2009 10:53 AM
Evo11V
107
May 9, 2005 11:07 PM
