MIVEC Timing discussion
Old Aug 10, 2011 | 02:22 AM
evodomUA's Avatar
Originally Posted by railhomie
Bump for a couple answers please!
Also, do tuners disable lean spool these days?
Why?
I mean what is the reason to do it?
Only If you are in process of calibrating your MAF or Injectors - yes...
Old Aug 10, 2011 | 02:34 AM
JohnBradley's Avatar
Yeah, turning the lean spool off is still a common practice. Normally its because I dont like what the factory settings are and rather than rework the lean spool table to match, I turn it off and do it in the tune.
Old Aug 10, 2011 | 02:53 AM
evodomUA's Avatar
what I really like in LS enabled - it is temporary lean condition (or even rich - depend on AFR mapping). i.e. it is one more safety feature in stock ECU - if you go HARD and LONG (out of LS time) you go richer AFR compare to short pulls.
Old Aug 10, 2011 | 04:41 AM
railhomie's Avatar
First of all: that's what she said.
Secondly: I can see both arguments, but I can't decide what to do myself! I think I might keep it enabled...
Old Aug 22, 2011 | 04:43 AM
ottoman's Avatar
what are your guys take on Mivec Tuning for cars that are heavily modded?
seems all mivec discussion pertains to bolt ons and mild cam type stuff?
I started a seperate thread without much luck, so I'm sort of cross referencing here..
https://www.evolutionm.net/forums/ge...questions.html
here's my Thought process on the subject..
due to mods like Cams, intake mani, turbo, larger intercooler etc..
air velocity and flow at low speeds is probably alot less as compared to the stock setup...
since boost is now coming on later as well.. (say 4.X vs the stock turbos quick spool)
so perhaps the stock mivec advance will now become TOO advanced in the 2-4kish range...
so perhaps the motor might benefit from less advance in the bottom end? to try and keep that airflow speed up a little bit?
Mr. Evo IX
May 24, 2016 09:21 PM
richardjh
68
Jan 16, 2013 06:58 PM
GST Motorsports
138
Jul 10, 2012 12:50 PM
SudzRA
87
Dec 15, 2011 04:23 PM
Juan Martinez
Jul 30, 2010 04:04 PM
