General non-information about factory ALS
Old Feb 28, 2012 | 01:07 PM
  #241
Murf's Avatar
Just checking to see if you are still needing the mani.
Old Feb 28, 2012 | 05:24 PM
  #242
211Ratsbud's Avatar
Yes im 100% in need of that
Old Feb 28, 2012 | 05:42 PM
  #243
laramie_05MR's Avatar
Are you having issues with your IX Mani?
Old Feb 28, 2012 | 07:53 PM
  #244
211Ratsbud's Avatar
I do not have an IX sas manifold. i opted not to have it shipped/gathered from foxbat. I intend to use the stock mani that Ill get from murph for a while. If the ingenuity gets necessary enough we can always go another route. I can always have it ported too.. A lot of options, just cinching down the pieces ya know
Old Mar 8, 2012 | 05:03 PM
  #245
foxbat's Avatar
Ratsbud, Laramie, any update?
Old Mar 9, 2012 | 04:49 AM
  #246
211Ratsbud's Avatar
manifold will be here today from murph. Ill get around to installing everything I can this weekend, been waiting over a month for cams from GSC.. so thats my hold up.
Old Mar 9, 2012 | 05:34 AM
  #247
211Ratsbud's Avatar
Scratch that the 12th fedex now twlls me.
Old Mar 9, 2012 | 07:12 PM
  #248
Murf's Avatar
Wth!!!
Old Mar 11, 2012 | 05:08 PM
  #249
211Ratsbud's Avatar
Thats what i am saying! lol..
I really cant wait. ! I need anti lag! hah..
well any thing worth having is worth the wait I suppose. Those GSC s2's will love the midrange I am producing. Our local SCCA region has fallen victim to the area's rising cost to use facilities, so a majority of the schedule takes place on a go kart track. Of which is 99% second gear. So the on/off'ness of this setup is surely gonna A) help B) hurt. if any thing will teach me to be a better driver!
Old Mar 11, 2012 | 07:47 PM
  #250
EvocentriK's Avatar
Ive played around with this on my JDM. Drilled out the banjo bolts etc. To me the issue doesn't appear to be getting air in. It's seems to be getting enough fuel in. Enlarging the banjo's didn't do much to be honest, not sure if I could even tell a difference, but as you dial down the injector time (s) the effect (noise only, absolutely no pressure increase) diminishes to nothing. It seem to sound a lot better on 5/6's and be pretty weak on CT9A's. You can get a decent run of smalls pops around 2.5-3.5K rpm but over that just a couple of pops that do nothing other than annoy motorists and probably damage the cat with time. I played with it, then disabled it again.
I haven't re-read everything in here to see what your individual plans are (some of you seemed to be going to modify the setup heavily) but in stock form with drilled out banjos, using many combinations of ECU settings, it does SFA.
Old Mar 12, 2012 | 04:34 PM
  #251
211Ratsbud's Avatar
I have different plans of attack: throttle body map switching like i first thought was necessary and just dump fuel in alt map when throttle body is closed incl - timing
or switch to a map which has really richened low loads/- timing
or use SAS equipped rom and tweak til content.
all im going by with this is JB said it could be done so Im going with that! Something can be accomplished
worst case scenario piggy back arduino and shielded motor board to get boost. Idk what really needs to be done yet as ive just got my manifold today. my cams will be on the way thursday. so after that we go bang!
Old Mar 13, 2012 | 07:37 AM
  #252
EvocentriK's Avatar
I should add I enrichened the decel load cells and ran the minimum of -10* timing which enhanced the effect but didnt even cause a flicker of the boost gauge and I was logging with evoscan and my MAP sensor was logging normal vacuum also.
I scared some people and a few dogs (which I felt terrible about) and it sounds the business, but could not get any change in logged vacuum/boost levels with it running as aggressively as the CT9A setup allowed. Hope you have better luck with the map switching, but I have a feeling you'll all need custom hardware to get any generation of boost (hell, even to get a reduction of vacuum) off throttle.
Old Mar 13, 2012 | 08:00 AM
  #253
211Ratsbud's Avatar
Its not going to raise your boost gauges unless you are on the uicp
Old Mar 13, 2012 | 08:01 AM
  #254
211Ratsbud's Avatar
Or you need a throttle bypass/ jack
Old Mar 13, 2012 | 08:59 AM
  #255
Murf's Avatar
I got to ask what turbo are you going to be running on this???
