General non-information about factory ALS
Old Jul 11, 2012 | 01:07 PM
  #451
Boosted RS's Avatar
http://www.motoiq.com/magazine_artic...ag-teaser.aspx
Old Jul 11, 2012 | 05:27 PM
  #452
marcoEVO9's Avatar
that is awesome. any more vids?
Old Jul 14, 2012 | 02:43 PM
  #453
foxbat's Avatar
Ratsbud, have you set your rom to full time OL? Would that be beneficial for adding more fuel in low rpm/load areas, same areas as -ve timing?
Old Jul 14, 2012 | 03:58 PM
  #454
211Ratsbud's Avatar
Yea I run full open loop. Haven't figured out the timing my car is happy with yet so this has been going slow. Might be false knock too..
Old Jul 15, 2012 | 06:13 AM
  #455
foxbat's Avatar
I'm eager to try low AFR figures (7.4 - 7.7) along with -20 timing in low load/rpm zone along with SAS tables enabled, but my car is currently in storage
I would like to try it with & without a throttle kick.
You could use conservative timing & continue to experiment with ALS. Why don't use det cans to verify phantom knock?
Old Jul 15, 2012 | 10:21 AM
  #456
211Ratsbud's Avatar
Don't have a set and I'm not familiar with how to use them
I can't even find conservative timing on my car it just knocks so randomly. Im missing a concept with timing nothing no amount of timing being pulled makes it happy
Knocking at 1 psi too sigh
Old Jul 16, 2012 | 01:44 AM
  #457
foxbat's Avatar
then it must be a phantom, it's very common when high degree cams are installed with aftermarket springs & retainers. I think you need to de-tune your knock control tables. Most common form of det cans is a battery operated unit with a conventional knock sensor & headphones, so knock could be audibly verified.
You seem handy with manual work, make your own det can
http://www.lukekailburn.com/detcan.html
Old Jul 16, 2012 | 05:21 PM
  #458
211Ratsbud's Avatar
Ok I'm going to do that. My afr swings a full point within minutes of back to back pulls. Pulling my hair out and preventing me from experimenting
Old Jul 17, 2012 | 01:39 AM
  #459
foxbat's Avatar
That might be normal with 'lean spool' on, disable LS if you're not comfortable with it.
Old Jul 17, 2012 | 04:35 AM
  #460
211Ratsbud's Avatar
Ls disabled I believe it's my iat method for sd
Old Jul 20, 2012 | 10:34 PM
  #461
211Ratsbud's Avatar
http://www.motec.com/forum/viewtopic.php?f=11&t=65
Old Jul 22, 2012 | 12:25 PM
  #462
211Ratsbud's Avatar
http://www.linkecu.com/support/docum...-tech-note.pdf
http://www.linkecu.com/link-help-cen...y/anti-lag-def
Couple of links to help with concepts
Old Jul 23, 2012 | 05:15 PM
  #463
211Ratsbud's Avatar
Ok since I have a FB 70mm throttle body, I screwed the throttle open and emplyed the stationary rev limit. Sounds like rotational idle ~1500 rpm.
next adding 12-13% throttle plus -20 in 40 load column, im going to try jacking the throttle to~30, or should I be jacking it 30 ontop of the normal idle 13?
clearly makes more pressure than normal overrun right? were on a start here.
I have the serious thought that SAS neeeds A LOT more air to work.
Old Jul 24, 2012 | 03:36 AM
  #464
foxbat's Avatar
What about fuel? since you run full time OL try inserting rich values in 0-40 load, would the ecu comply?
With stand alones, I usually jack the throttle by 12-15% (2500-3000rpm).
I'll not be surprised if you end up getting a stand alone :]
Old Jul 24, 2012 | 04:40 AM
  #465
211Ratsbud's Avatar
I really want a haltech or vipec pnp you add 12-15 to the base throttle correct?
I haven't messed much with fuel cause I only have clutch in to keep rpms adequate during idle .. Would be easy to fix if I wanted that pin grounded based on vss
I will tinker a little more tonight standalone is looking much more better every day. I got my tune pretty decent on the s2 cams. Rescaled my SD tune and had to take a ton of timing out of her I guess it only likes 1 degree at peak load!
I'll switch to the 8858 3dsd rom here shortly. I replaced my iat so I'll have to find a dedicated bung for the sas valve. Kinda why I peeked into the throttle jacking. Boy there is an obvious difference in the bangs sas vs jacked. It leads me to suspect a lot more air is needed via sas
