Evoscan logging problem
Old Nov 5, 2011 | 03:40 AM
catman78's Avatar
hi all,
V7 95630706
cannot log the following:
Boost Error
WGDC Correction
my current settings:
Attached Thumbnails Evoscan logging problem-mutt.jpg   Evoscan logging problem-scan.jpg   Evoscan logging problem-flash.jpg
Old Nov 6, 2011 | 05:32 AM
catman78's Avatar
ok here's a few more tables.
I'm using Omni 4Bar sensor
Do formulas look correct.
evoscan:
Attached Thumbnails Evoscan logging problem-ecuflash.jpg   Evoscan logging problem-evoscan.jpg
Old Nov 7, 2011 | 02:50 AM
catman78's Avatar
Anyone !
Old Nov 8, 2011 | 02:16 PM
catman78's Avatar
Ok, last effort for some insight...
Could it be I see no correction because my wgdc is so perfectly tuned?
Old Nov 8, 2011 | 03:10 PM
Raptord's Avatar
If your WGDC map was spot on then boost error would be 0. Can you post your boost adder, desired boost and WGDC correction tables?
Old Nov 8, 2011 | 03:38 PM
catman78's Avatar
Thanks for chiming in Raptord.
Here's what I have.
I'm @ sea level.
Old Nov 8, 2011 | 03:48 PM
Raptord's Avatar
What does your OMNI sensor read if you log it with the ignition ON but the engine NOT running?
Old Nov 9, 2011 | 02:07 AM
catman78's Avatar
Substituted your formula for boost err correction.
with ignition on, Boost(Omni) reads as follows:
Old Nov 9, 2011 | 05:48 AM
Raptord's Avatar
Change the 14.7 in your OMNI formula for a 14.5. Unlikely that that's the problem but it'll get your logged boost closer to what it actually is.
I'm not really sure what else it could be that's causing your correction to not work, hopefully someone else will chip in with new advice.
Old Nov 9, 2011 | 06:34 AM
catman78's Avatar
thanks, will do. I was under the impression 14.7 was used for sea level?
Old Nov 9, 2011 | 07:18 AM
Raptord's Avatar
Usually yes, but weather etc can make it vary a bit. Mine is 14.5 as well and I'm pretty much as sea level.
jakgal04
Mar 28, 2016 08:16 AM
jpierson77
Jul 9, 2009 04:35 AM
nj1266
May 28, 2009 10:05 AM
ethompson
Dec 22, 2007 07:39 PM
PlanoEvo
Oct 19, 2007 05:08 PM
