Adjusting rev-up at start
Old Nov 9, 2011 | 12:39 PM
cmspaz's Avatar
I've got an '03 VIII with Tephra v7, running E85, and I'm looking to change the rev-up when the car is at operating temp.
When it's cold, it starts fine, but when it starts hot, it's all stumbly and sometimes dies immediately after catching. The solution I've found is to manually give it ~5% throttle when I turn the key, and it starts great, so I'm looking to implement that into the ROM with around a 1500rpm rev-up such as what it would do on a cold start.
I'm guessing the table to edit would be the "Desired ISCV initial step position with A/C off - neutral", and that the goal would be to set the steps relatively the same or at least higher across the board as the lower temps, correct?
Old Nov 9, 2011 | 02:43 PM
Raptord's Avatar
How exactly does it behave when it starts? Does it rev up to ~1200 rpm for a fraction of a second and then almost stall, or does it simply not rev enough when it starts?
Old Nov 9, 2011 | 03:02 PM
cmspaz's Avatar
It doesn't rev up enough, it catches and then stumbles around at ~500rpm before coming up to target idle (898).
I did try adjusting the initial ISCV steps tables, but they also affect normal idle as well, so I got my rev-up, but the car then idled at 1300rpm, which is obnoxious and far from ideal.
Old Nov 9, 2011 | 03:32 PM
Raptord's Avatar
Ok, if they don't raise enough just as it starts it should be the startup ISCV table that needs to be adjusted. It isn't defined in Tephra so you'll need to check the thread below to see if the tables are defined for your rom. The tables in the OP are for 88590015, so not you since you have an VIII.
https://www.evolutionm.net/forums/ec...sassembly.html
Old Nov 12, 2011 | 12:50 AM
84ace's Avatar
Have you tried manually adding more air via the screw near the TPS?
Old Nov 12, 2011 | 09:38 AM
sweeney87's Avatar
or doing idle reset
Old Nov 13, 2011 | 10:57 PM
EVO8emUp's Avatar
So this is just a starting issue? Once it's running, you can rev it and it returns to idle just fine, right.
The BISS is the last thing I would mess with at this point.
Old Nov 13, 2011 | 11:45 PM
taylorgang's Avatar
Not to thread hi-jack... but I've got a similar issue
Tuned on e85 right now and my warm start up is pretty crappy...
When the engine is cold it starts right up, jumps up to about 1500-2k rpm and makes its way down to idle which is around 1000 after like 30 seconds or so...
However, if I shut the car off and try to start it a few minutes later the rpms won't jump up, and it'll either die right away or it'll idle at about 500 rpm for a bit, then jump up to 1000 rpm.
It was really bad when the weather was hotter too
Old Nov 16, 2011 | 12:48 PM
Dynotech Tuning's Avatar
Is this car on speed density or MAF?
-Jamie
Old Nov 17, 2011 | 07:58 AM
taylorgang's Avatar
-Jamie
It is MAF with a recirc Synapse DV
I have a video of it happening if anyone is interested in seeing it. Basically, it died 3 times when I tried to start it, then the last time I start the car I gave it a little throttle and it started up.
Old Nov 17, 2011 | 09:41 PM
Boosted Tuning's Avatar
For the warm start issue, you need to either add or reduce fuel at the coolant temp where it is having trouble in this table, "Injector Cranking Enrichment IPW Adder (Main)"
ezzey
May 9, 2016 09:40 AM
EvilTechnology
Jun 24, 2015 09:22 PM
HornstarBU
Mar 24, 2015 02:25 PM
TwinZEvo
For Sale - Cars For Sale
Jul 8, 2014 11:49 PM
