Tephra NLTS Problem - Have searched.
Old Mar 21, 2012 | 09:48 PM
  #31
HyperDisorder's Avatar
Originally Posted by nemini
i too could not get the stationary setting to work i have not yet driven the car. i just would like to confirm that in the tephra options section i have my alternate maps on 2 ics and nlts on 1 acdof. is this all correct.
I should let you know that i have ran evoscan and can see the clutch switch switching from 201 to 203
Hmmm, I think I've made a mistake with the mod! Pin 88 must be a ADC input, rather than a high/low input. You should change C802 back to C801, and that will fix it. The number on the end refers to the bit that is being tested, and in your case bit 1 is toggling with the clutch switch. On mine it was bit 2.
A non-ADC input on the ECU would be ideal if anyone knows of a spare one, but otherwise I'll happily stick with pin 88.
In testing I found that having the tephra mod options on either ICS or ADC0F didn't matter. I currently have it on ICS in case you're wondering though.
Off on a tangent seeing this is a mostly a 96260709 related thread, I have a new 96260009 xml with a lot of fixes (mostly just to correct incorrect axes though). PM me if you want it, as I think your evo7base xml will need fixes to work with it.
Last edited by HyperDisorder; Mar 22, 2012 at 02:57 PM. Reason: 8's and B's look too similar
Old Mar 22, 2012 | 02:45 PM
  #32
nemini's Avatar
ok so now im lost lol. im new to all this so need a fair bit of help. i copied the section of code you added on post 15 to my tephra xml (96260709). where abouts would i find CB02 so i can change it back. would it be easier to change to your 96260009 xml and that would sort it out. sorry to be a pain
Thanks Neal
Old Mar 22, 2012 | 02:57 PM
  #33
I meant C801 not CB01! I was a bit blind when I wrote that. I'll edit my post now.
Just edit this table's value back to C801: "Set to C802 for NTLS. Originally C801"
Once you've done that, you should be good to go!
The 96260709 xml is the right place for it. But of course you can still have my updated 96260009 xml. It doesn't have anything to do with the fix for NLTS though. I'll PM you.
Old Apr 3, 2012 | 06:52 PM
  #34
Update - we got nemini's NLTS issue sorted. The original xml I posted up is still correct in case anyone's wondering.
And as for reliability, a word of warning - 6 speed transmissions aren't as robust as the 5's! I've used NLTS occasionally for over half a year with no problems (yet), but I know that another wasn't so lucky, losing 6th gear.
Old Apr 4, 2012 | 02:11 PM
  #35
nemini's Avatar
Hey Guys
Hyper is right nlts works great but after a few time of using it 6th gear stopped working in my car
im am sure this is because of selecting 2nd to 3rd to quickly. You can still use nlts but be nice on your gear changers. if you are looking to use it to drag race buy a 5 speed first.
Neal
Old Jun 19, 2012 | 10:22 AM
  #36
Nsk's Avatar
Nsk
Hi guys! I have an Evo 7 JDM and i run 90550001 Tephra v.7 ROM.
My 88 pin used for cam sensor. So i think i must use the 43 pin. Right? What should i do with my xml? Is there any ideas?
When i activate my NLTS revs drops without pushing the clutch pedal, when i just accelerate....
Old Jun 20, 2012 | 01:06 PM
  #37
Nsk's Avatar
Nsk
It seems like an ECU always see the (-) and do RPM drop just when all tresholds come... May be i use the wrong pin? I think i must to do some changes to XML...
Anybody can help?
Old Jun 20, 2012 | 01:20 PM
  #38
mt057's Avatar
What is your tps threshold setting?
Old Jun 28, 2012 | 10:10 PM
  #39
Nsk's Avatar
Nsk
It is 95% or something about. I tried to change it.
Old Oct 17, 2012 | 09:17 PM
  #40
audiofan's Avatar
Bump!
Were you able to make it work????
I'm still trying to make NLTS work on my EDM evo VIII
Old Aug 27, 2013 | 03:18 AM
  #41
rasssta's Avatar
Hi,
bumping this a bit.
I'm running 96531706 (v7+sd) on a Evo8 JDM and have been trying to get NLTS to work for a while now. I've rewired the stock clutch switch into the box on pin #88 (JDM 3 plug), and when clutch is up it shows 203 and when I press down the clutch I get 201. I wanted to get rid of the clutch depress requirement when booting the car as well so that's why I've used the stock switch.
In detail I've cut the red wire going to the stock clutch witch and wired the red "output" from the switch into the box, while the white one is untouched.
When doing the 'garage test' NLTS doesn't trigger. I've even tried pushing down the clutch when I start the car and then putting down the throttle and releasing the clutch to test if I had the 203->201 wrong (saw that someone used to invert the signal through a relay somewhere in the thread). Still didn't work though.
And of course I've inserted the XML hacks. But still it doesn't work.
Anyone has any ideas?
//Rasmus
tephra
Apr 22, 2026 11:03 AM
tephra
Aug 11, 2019 09:05 AM
tephra
Aug 19, 2016 10:07 AM
egis
Aug 25, 2015 05:28 PM
TouringBubble
Feb 11, 2008 02:01 PM
