Anyone able to read 96260012?
Old Jan 1, 2012 | 03:58 AM
XLR83N's Avatar
Hey guys,
My car use to be on 96260007 xml but after having a recent tune it got changed.
From much searching and digging I have found that it is now on 96260012 xml. I have managed to find an xml for it but when I look at the tables (like fuel and timing) I can see that the scalings are all wrong.
Are there any experts out there that may be able to help me?
I have attached my hex and xml files (obviously change the txt to a xml file) for anyone to have a look at.
Also my Tephra section seems to be wrong also, shows the value 65535 for everything, if anyone knows how to fix that too that would be great.
Thanks again,
Mike
File Type: txt
File Type: hex
Old Jan 2, 2012 | 12:40 PM
HyperDisorder's Avatar
Given that it is 96260012 (I know that it says it is) and the xml is correct, those scalings cannot be doing you any good.
What version of the Tephra mod is it?
The xml I'm using to look at it works with another 96260012 with V5.1, so surely this rom should be good too.
If it makes no difference to you, use this xml, as your one doesn't work in EcuFlash 1.43.3150. I think that I was given the same xml that you are using and the 1bytefactor scaling was missing - if you want to fix yours instead.
File Type: txt
Old Jan 3, 2012 | 04:59 AM
Prolifik's Avatar
thats weird.....
scalings are off in both the XMLS posted in this thread aswell as my own......
20psiMR
Feb 25, 2018 08:03 PM
RngrYogi
Jul 9, 2011 07:12 AM
Ceddy
Apr 28, 2010 09:08 PM
gunhaha
Mar 5, 2009 06:39 AM
7oey
Jan 27, 2008 05:16 AM
