full closed loop possibility?
Old Jan 11, 2012 | 07:16 AM
211Ratsbud's Avatar
If you raised your threshold for closed loop to open and had mr freds patch would it be possible to use the fuel map to target afrs at wot? Higher powered ecu ie motec and probably more i believe use lamba as live fueling adjustments. Possible to implement two fully functioning wbo2 as fail safe and use alt maps as a 2nd failsafe ipw map?
What reasons make this unsafe or reliable for those who would even necessitate such? Are those able to be overcome by technicalities in hardware setup and install? Would this provide year round tune infallibility?
Old Jan 11, 2012 | 05:30 PM
project_skyline's Avatar
WB feedback is supposed to be used to compensate for changing conditions not to totally run the car.
Even then its only designed to work in idle and low load situations. All the ECU's you listed do have that ability but again it wasn't made to be used at high power WOT. The job of a tuner is to calibrate the ECU to its specific configuration not tell the ECU to tune itself.
Old Jan 11, 2012 | 07:48 PM
Raptord's Avatar
I believe I've read somewhere that the stock ECU likely wouldn't be fast enough in its adjustments in order to maintain a desired AFR at WOT.
Old Jan 11, 2012 | 08:52 PM
n2oiroc's Avatar
its a bad idea. if you have a wideband going bad it can ruin the engine. some correction is good, but most ecu's dont have much for compensation or safety features.
Old Jan 12, 2012 | 04:11 AM
211Ratsbud's Avatar
Gotcha
Does fuel trims cause any changes to ol fuel? I heard Subaru does this with "D" fuel range.
Old Jan 12, 2012 | 05:50 AM
Dynotech Tuning's Avatar
There are factory vehicles that run full-time closed loop operation with wideband feedback. I believe the '06 VW GTi was one of them. I would prefer to use it for auto-tuning and then save it as open loop settings. It would save a lot of time
-Jamie
Old Jan 12, 2012 | 06:58 AM
211Ratsbud's Avatar
I think there would be a way of making it failsafe, safely. Auto tune program to map ipw right?
Old Jan 13, 2012 | 02:16 PM
Yeah, you set a desired AFR curve and it corrects to get close to the target. Once you have it dialed-in, you save it as your openloop map and you are basically done. Other than a few tweaks and smoothing.
-Jamie
4b11slayer
Jul 28, 2017 10:33 AM
nicolassabra
Jun 7, 2013 06:01 PM
johnnyr55
Apr 12, 2008 06:54 PM
evopower1021
Jun 13, 2007 09:58 AM
HiVoltEVO8
Jul 30, 2006 05:16 AM
