Wrong ROM?
Old Mar 8, 2012 | 07:48 AM
Inprogress's Avatar
Wrong ROM?
How can someone tell if they have a incorrect ROM flashed on their car? I recently had codes pulled and had like 4-5 "invalid codes" along with P0138/p0139, P0171, P0113, P1235.
My only mod is a TBE, i do have a very tiny exhaust leak in the downpipe. I bought the car used last weekend. I've swapped all fluids, changed spark plugs, got fuel relay updated, got my fuel pressure line zip-tied, and did a compression test which checked out fine.
Any thoughts? The codes are really freaking me out.
Old Mar 8, 2012 | 09:01 AM
Woop's Avatar
"your ROM is the program that runs on the computer in your car. We call it a rom because it is written to flash chips. The ECU (computer) never writes to these chips. Only the factory and dealer will change the ROM." - Golden
What you have confused possibly is ROM and Codes. Codes are what triggers the SES(service engine soon) light.
CODES: p0138--Heated oxygen sensor (rear) circuit high voltage
p0139--Heated oxygen sensor (rear) circuit slow response
p0171--System too lean
p0113--Intake air temperature circuit high input (sensor 1)
p1235--Mass airflow sensor plausibility
TurboBack causes the first 2. Erase them by canceling the code using software such as EcuFlash.
Evos are fine with either an exhaust or open element intake but run lean with both.(my experience)
Last 2, i would check all intake connections etc.
I AM NOT AN EXPERT... Just some helpful advie
Old Mar 8, 2012 | 09:18 AM
Inprogress's Avatar
Thanks for the reply Woop, I do appreciate it!
I do understand the difference between ROM and code, I was told by a local tuner that sometimes the incorrect ROM can be flashed to a car...doesn't each car have a certain ROM with a particular ID on it? That's what I'm wondering, if my car has been flashed with a incorrect ROM...Tephra had some ROMs listed in his V1 thread...
2008 USDM 5MT - 52680122
2008 USDM SST - 52690122
2010 USDM 5MT - 55570106
2010 USDM SST - 55580106
2010 USDM RA SST - 55590107
2008 EDM/AUDM 5MT - 53040110
2008 EDM/AUDM SST - 53050109
2008 JDM 5MT - 52360118
Does the 2008 5MT only have 1 sort of ROM it can have on it?
Old Mar 21, 2012 | 12:00 PM
Woop's Avatar
Rom Id Year Market SubModel Trans Download as a File Download Base as a File Last Modified
52360016 2008 JDM Evolution X 5MT Download - 52360016 2011-01-11 21:27:11
52360018 2008 JDM Evolution X 5MT Download - 52360018 2011-06-13 10:17:50
52370023 2008 JDM Evolution X SST Download - 52370023 2011-08-07 09:37:35
52370024 2008 JDM Evolution X SST Download - 52370024 2011-10-11 08:02:18
52550003 2008 EDM Evolution X 5MT Download - 52550003 2011-01-11 21:27:11
52680015 2008 USDM Evolution X 5MT Download - 52680015 2012-02-01 09:26:51
52680016 2008 USDM Evolution X 5MT Download - 52680016 Download Base - 52680015 2011-01-11 21:27:11
52680017 2008 USDM Evolution X 5MT Download - 52680017 Download Base - 52680015 2011-01-11 21:27:11
52680018 2008 USDM Evolution X 5MT Download - 52680018 Download Base - 52680015 2011-01-11 21:27:11
52680019 2008 USDM Evolution X 5MT Download - 52680019 Download Base - 52680015 2011-01-11 21:27:11
52680020 2008 USDM Evolution X 5MT Download - 52680020 Download Base - 52680015 2011-01-11 21:27:11
52680022 2008 USDM Evolution X 5MT Download - 52680022 Download Base - 52680015 2011-01-11 21:27:11
52680024 2008 USDM Evolution X 5MT Download - 52680024 2011-01-25 10:03:07
52690019 2008 USDM Evolution X SST Download - 52690019 Download Base - 52690021 2011-01-11 21:27:11
52690021 2008 USDM Evolution X SST Download - 52690021 2012-02-28 17:37:31
52690022 2008 USDM Evolution X SST Download - 52690022 Download Base - 52690021 2011-01-11 21:27:11
52690024 2008 USDM Evolution X SST Download - 52690024 2011-04-30 22:17:07
53040007 2008 EDM Evolution X 5MT Download - 53040007 2011-02-16 18:03:40
53040008 2008 EDM Evolution X 5MT Download - 53040008 Download Base - 53040007 2011-01-11 21:27:11
53040010 2008 EDM Evolution X 5MT Download - 53040010 2012-02-01 09:28:37
53050006 2008 EDM Evolution X SST Download - 53050006 2011-04-22 17:45:18
53050007 2008 EDM Evolution X SST Download - 53050007 Download Base - 53050006 2011-01-11 21:27:11
53050009 2008 EDM Evolution X SST Download - 53050009 2012-03-02 20:29:47
53050011 2008 EDM Evolution X SST Download - 53050011 Download Base - 53050012 2011-01-26 11:37:46
53050012 2008 EDM Evolution X SST Download - 53050012 2011-06-01 17:45:40
as per goldenevo.com check it out. i would ask a tuner for the correct definition of your rom. more than likely they will have it if they are reputable and understand what they are doing. the ROM is "read only memory" and every evo has their own rom and some being the same. The ID is what distinguishes the type of ROM the car has
ahowelltech
Jul 18, 2015 11:45 AM
mrfred
Apr 9, 2015 11:20 AM
92 GSR-4
May 9, 2014 10:08 AM
jdmevo123
Apr 5, 2011 03:27 PM
iam12nv4
Dec 30, 2007 04:01 PM
