WGDC drop/AFR safety gets 0..5vdc from ? pin
Old Apr 19, 2012 | 05:57 PM
C6C6CH3vo's Avatar
Hi, can't seem to figure out where the WBO2 analog out signal ties into the ecu for use of AFR safety boost drop feature
Is it a spare pin?
Anyone use it
Thank you.
Old Apr 19, 2012 | 06:47 PM
Benja's Avatar
Rear 02 usually.
Old Apr 19, 2012 | 06:57 PM
C6C6CH3vo's Avatar
ah ha, probably why it didn't work I plugged it into frt o2
thanks, I'll swap pins at ecu
Old Apr 20, 2012 | 01:04 PM
C6C6CH3vo's Avatar
Thanks Benja! It works now
Old Apr 20, 2012 | 10:28 PM
C6C6CH3vo's Avatar
quick snapshot of it in action. 1st was lean so it engaged and disengaged at 2nd and 3rd.
I tightened the nifty settings provided in tephra7 awesome rom to make it more responsive and less prolonged.
lt blue = rear O2 feed from LC1
magneta - load
purple - afr
yellow - WGDC
brn - rpmnd
Attached Thumbnails WGDC drop/AFR safety gets 0..5vdc from ? pin-afr-thing.png
mrb00st
E85 / Ethanol
189
Oct 11, 2024 04:59 PM
mrfred
May 1, 2020 10:16 AM
evoscan
52
Jun 20, 2017 01:46 AM
tscompusa
10
Dec 12, 2016 10:32 AM
jason42003
Aug 1, 2013 07:35 PM
