2008 EvoX NO XML DEF OUT THERE?!?
Old May 4, 2012 | 10:54 AM
silverbullet08's Avatar
Trying to read this car. Its a 2008 evo x 5 speed. No matter what it tells me UNKNOWN ROM IMAGE after I try to read it each time and gives me no access to any tables. I opened it up with XVI32 and it shows the internal ID hex and address as 52680027, So I changed a XML with notepad from 52680022 to my required id. I saved it into my rommetadata and I still get the same issue. Everywhere i look for this xml I cant find anything higher than a 52680024. I attached the file im working with. any help would be appreciated.
File Type: bin
Old May 4, 2012 | 12:49 PM
philr8's Avatar
Here you go, some of the load and rpm columns arent right but it will get you going
File Type: txt
Old May 4, 2012 | 02:08 PM
JohnBradley's Avatar
Or just swap to a 0015 rom and call it a day?
Old May 4, 2012 | 02:51 PM
Im just learning all the ins and outs of ecuflash. Im used to hptuners and cobb. Can I just flash in a different rom id that I already have a xml for and matches year/trim/motor then rescan it to make it work? I know if you flashed in a different operating system on hptuners from another vehicle sometimes it would require a dealer flash and lock up the ecu from tuning. Thank you for the info!
Edit: I put that xml in my rommetadata file and I still get Unknown rom image when I try to view the rom
Old May 4, 2012 | 02:54 PM
In this case yes. The 5268 family is all the same for operation of the engine.
Old May 4, 2012 | 03:00 PM
Thank you very much sir.
Old May 4, 2012 | 04:47 PM
Where is the best place to download a new rom? I looked on ecvoscan website and couldnt find one or on the evowiki site.
Old May 4, 2012 | 05:14 PM
Daluv's Avatar
http://goldenevo.com/ should have you covered.
Old Nov 26, 2012 | 03:20 PM
Hung Phantasm's Avatar
So what is the difference in changes from 0015 to 0024 ? Is one more ideal then the other?
richardjh
May 24, 2026 12:49 AM
mindfreakattack
Nov 7, 2016 07:08 AM
monkeyevo
Dec 3, 2015 10:22 PM
NZRipper
Aug 19, 2015 10:27 PM
namwens
Oct 28, 2009 07:00 AM
