Trying to flash my 05 Evo 8 back to stock
Old Jun 18, 2012 | 08:49 PM
DubsE46's Avatar
So I need help guys, I'm trying to flash my 05 Evo 8 back to stock
Can anyone point me in the right direction on how to find a compatible stock rom
Thought I found one but the car won't even start, so I flashed my old messed up rom so I could move the car
Help?
attached to this thread is the messed up rom the car currently has
File Type: hex
Old Jun 18, 2012 | 09:11 PM
black-dsm's Avatar
did you put your immobilizer code or disable it on the new rom? if you did not then thats why it didn't start.
Old Jun 18, 2012 | 09:20 PM
DubsE46's Avatar
yes i put my immoblizer code, checked it multiple times and still nothing
Old Jun 19, 2012 | 04:33 AM
Bigweba2's Avatar
Check the downloads section on the kiwi page for your stock rom.
http://evoecu.logic.net/wiki/Main_Page
Old Jun 19, 2012 | 10:04 AM
HaVoC187's Avatar
I can't open the rom you posted?
What rom did you try to flash the car with?
Try one of these 2 roms :
http://speedy.sh/fdQ7t/96940011.HEX
http://speedy.sh/YqKaG/96530006.HEX
From http://evoecu.logic.net/wiki/96530006 :
The immobilizer functions differently between 96940011 (or your original ROM) and 96530006, and you will need to change the behavior for the car to start correctly. You can either disable the immobilizer completely, or change the 96530006 immobilizer behavior to function like your original ROM did. Only do one, or the other; if you disable the immobilizer completely, there is no need to do the following, and if you do the following you should definitely leave the immobilizer enabled for your own security.
To change the behavior, you'll need to add the following to both 96940011.xml and 96530006.xml (or the base XML for the ROM you're coming from):
<table name="Immobilizer Hex" category="Misc" address="ffa" type="1D" level="2" scaling="Hex16"/> Then, open your original 96940011 ROM, and copy the value from the "Immobilizer Hex" table under the "Misc" section (probably 0x0058). Open your new 96530006 ROM, and open the "Immobilizer Hex" table. You'll see that the value is probably 0x004D; paste in the value you copied from your 96940011 ROM in its place.
Then, do the same thing for the "Immobilizer" table under the "Misc" section.
At this point, your car should start as expected, with the immobilizer functioning correctly.
Old Jun 19, 2012 | 09:57 PM
DubsE46's Avatar
Is there a difference between bin. And hex. Files?
Sorry I'm new to this
DubsE46's Avatar
Thanks havoc I will try that
Old Jun 21, 2012 | 04:44 PM
DubsE46's Avatar
Sooo I still cant get the car to start, but it'll start with my messed up map.
I managed to set the injector scaling too 513 and the car idles fine but the Maf has to be unplugged
Where can I go to change Maf settings?
senate6268
Lancer Engine Management / Tuning Forums
703
Dec 5, 2022 02:44 AM
Decil
Apr 21, 2017 12:28 AM
EvoCrazyyy
Dec 11, 2011 04:52 AM
R18eclipse
18
Jul 6, 2011 09:04 AM
nismo1982
Sep 1, 2009 05:12 PM
