Knock even with timing pulled
Old Jul 2, 2012 | 06:29 PM
Raptord's Avatar
I'm in a very similar situation, which seems to be the same for many evos. One day before a track day I decided I would try all fuel & timing possibilities to try and get rid of similar knock I was getting during spoolup. I tried both lowering and increasing timing by 5° compared to my regular map. No difference in knocksum. I then tried richening and leaning out by .5 AFR compared to my regular map. Still no difference. The only thing I didn't mess around with was MIVEC. I guess that'll be on the to-do list when my turbo gets back from MAP.
Old Jul 2, 2012 | 06:45 PM
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
Originally Posted by JohnBradley
Are the lifters noisy? What valvesprings?
lifters aren't more or less noisy than my buddies evo, the valve springs are stock. can the mivec map be to aggressive?
Old Jul 2, 2012 | 07:58 PM
211Ratsbud's Avatar
I have had a heck of a time. I even made a thread about s2 cams and knock tables to see if it was typically needed adjustment. JB suggested not, and my springs/ret's are audibly quiet too but upgraded on my setup from GSC. I think this S2 cams are just picky about mivec and ign timing. I did try to take out some mivec advance with better results. Ill post my map not fully tuned VE wise but getting there.
i have started smoothing and taking out some advance at low loads on the mivec, and the ign timing. My KPA load table may be different from yours, so keep that in mind.
File Type: hex
Old Jul 2, 2012 | 08:21 PM
ty 211ratsbud i feel a little better about my timing map its still more pulled than yours but not far off. your mivec is a little tamer in some areas and more aggressive in others so i might give it a shot. i see u messed with the knock threshold instead of the multiplier so i might combine ur threshold change and my 5% increase of the multiplier.
Old Jul 3, 2012 | 10:04 AM
211Ratsbud's Avatar
What intake mani are you on?
Old Jul 3, 2012 | 10:31 AM
Stocker mani
Old Jul 3, 2012 | 11:55 AM
JohnBradley's Avatar
If you are getting compressor surge (which can be interpreted as knock) down low where this is happening then yes, the MIVEC can be too aggressive.
BOV will do it, rattles from exhaust, noisy lifters, valvefloat, etc.
Old Jul 3, 2012 | 12:14 PM
Threw on stock mivec map and tada worst I saw was 3 counts with a/c on
Old Jul 3, 2012 | 12:46 PM
211Ratsbud's Avatar
Interesting, can you post your load kpa table?
Old Jul 3, 2012 | 01:02 PM
I am off speed density atm to fix the knock. (I was in the process of doing speed density when I got tired of chasing 2 problems at once.)
Old Jul 5, 2012 | 05:17 AM
211Ratsbud's Avatar
Did you make any progress yet?
Old Jul 5, 2012 | 05:32 AM
Still haven't touched it much since I uploaded stock mivec Map. Will continue next week cause I have little time this week.
03GS-T
Oct 23, 2016 09:55 PM
EvilEvolution8
Dec 20, 2015 07:56 AM
Colt4g63
Mar 22, 2008 04:03 PM
krillin
Feb 6, 2007 10:01 AM
spoolinspyder
AEM EMS
26
Mar 12, 2006 05:15 PM
