Random Leaning While Crusing
Old Aug 5, 2012 | 10:41 PM
Gordian79's Avatar
My car has a leaning problem while crusing at Highway speeds 65-70mph.It does it randomly but usually when going up a hill.It also does it on flat roads.when im crusing and i tap throttle to get a little more speed itll start bucking and afrs will read lean condition.Ive attached 2 logs where you can see wdb afr randomly going lean.
Ive changed front o2,Closed sparkplug gap to .022.It has a brand new spooling up cop.It also did it with stock coils.
Old Aug 6, 2012 | 08:46 PM
CDrinkH2O's Avatar
Looks like it could be a fueling problem as the AFRMAP decreases and the load increases when you press the accelerator. Check the fuel pump and the fuel pressure at the rail. For some reason the injector pulse width is not increasing which it should as the AFRMAP decreases. Are you running an open filter?
Old Aug 6, 2012 | 09:00 PM
Gordian79's Avatar
I will double check fuel pressure and check fuel pump.Open fuel filter?
Old Aug 6, 2012 | 09:20 PM
evilempire76's Avatar
He probably means open air filter. What mods are on the car?
Old Aug 6, 2012 | 09:34 PM
Gordian79's Avatar
yes open air filter im running speed density.
fp black,bf272s,built block,fic 2150s,double pumper.
I did a little searching and this maybe my problem
https://www.evolutionm.net/forums/ve...sers-read.html
Old Aug 7, 2012 | 09:57 AM
charlie.tunah's Avatar
SD tune related? Thats kindof a big detail to leave out when posting about an issue like this.
Old Aug 7, 2012 | 11:55 AM
JohnBradley's Avatar
The tune isnt finished...looking at the logs and sending a revision over later this afternoon.
Aaron
KYjerry414
107
Dec 7, 2017 04:46 PM
89turbosupra
Feb 12, 2016 06:03 PM
Dragking2189
Dec 15, 2012 10:24 AM
09_Lancer_GTS
Lancer Aftermarket Forced Induction Tech
14
Feb 21, 2011 03:16 PM
vxevolutionxv
11
Jul 6, 2009 09:37 PM
