2012 Knock Tables?
Old Aug 21, 2012 | 08:06 PM
Moore Auto's Avatar
2012 Knock Tables?
Hi guys, I have a 2012 MR that we put an AMS 2.2L shortblock in, and being a built engine it's a little noisy. I've noticed there's only 1 defined rom for the '12 MR and it doesn't have the knock tables defined. Anyone find theses tables yet? Are they the same as previous years? Can I just copy the tables from an '11 MR definition and paste them in the '12 def? Not sure if it works like that, but any help would be much appreciated. Thanks!
~Chris@MooreAutomotive
Old Aug 22, 2012 | 12:39 PM
black E's Avatar
There was some talk that some of the 2011 ROM's would work on the 2012. I would try that if I was you.
Old Aug 22, 2012 | 12:49 PM
keyboard2010's Avatar
The 2012 ROM will not backdate to a 2011 without bench flashing the ecu
Old Aug 22, 2012 | 01:35 PM
Moore Auto's Avatar
So, could I bench flash back to a 2011 MR rom and it should run? I read Aaron's thread about rom interchanging, but he did a GSR. I wasn't sure if it would work on the MR because of the SST.
Old Aug 22, 2012 | 01:40 PM
JohnBradley's Avatar
... doublepost
Old Aug 22, 2012 | 01:41 PM
I have an MR to try that is here for the cam testing portion of the why do 2012s suck. I will pull it up and benchflash it and see what it does. If it does work I would actually backdate to a 2010MR and use TephraMod if you prefer that. The 2010 is better defined either way so I would go all the way back to it.
Aaron
Old Aug 22, 2012 | 02:59 PM
Golden's Avatar
Yes, but you should probably to to a 2010 over the 2011. :-)
Old Aug 22, 2012 | 03:06 PM
Benchflashed and it works great. Like I said use the 2010MR stuff as its better defined than the 2011.
Old Aug 22, 2012 | 03:11 PM
masafina's Avatar
ok, when you say benchflashed are you talking about take out the ecu from the car and do the recovery flash like a brick ecu???
sorry if i not made myself clear
Old Aug 22, 2012 | 03:15 PM
Yes thats what I mean, but I have a cable I made that I can actually leave the ECU in the car, hook up the connector to the ECU in the engine bay, and then flash.
BenchFlash means the recovery mode for Bricked ECU.
Aaron
Old Aug 22, 2012 | 03:19 PM
masafina's Avatar
So I bench the ecu, do the recovery mode and put back in the car but this time Im gone use the 2010 rom, right?
Old Aug 22, 2012 | 03:37 PM
Benchflash in recovery mode
Then flash in normal mode
Then reinstall ECU
Tune as normal
Old Aug 22, 2012 | 03:46 PM
black E's Avatar
Then reinstall ECU
Tune as normal
Nice!
Old Aug 22, 2012 | 04:08 PM
masafina's Avatar
Then reinstall ECU
Tune as normal
thanks
Old Aug 22, 2012 | 07:18 PM
Moore Auto's Avatar
Ok, awesome! I'm gonna give that a shot tomorrow and hopefully this thing makes some power, lol. Thanks Aaron and Golden!
