New EVODROID7 EvoScan Android GPS/Logger/Reflashing CarPC Touchscreen Review
I am quite impressed with all the work that you are doing "evoscan".
I have an Evo VI TME with a Motec ECU ( I am not going to get any display system from them, their prices are outrageous !)and I have a Zeitronic Dash Daq displaying a few data but the screen is really a bit small and I have difficulty to read data (two gauges + digital). It works quite well but impossible to read in the action (I need glasses to read !).
Is it possible to use your Evodroid connected to the sensors directly?
Sensors are: EGT, boost, water temp, intake air temp, AFR (Zeitronic). I have oil temp/pressure on a separate gauge.
Thanks
Thanks
automatically put the tablet into deep sleep (1-2% battery drop per day with the car off). When power is restored, it automatically wakes up. Maybe this is something you could look into in the future. Basically, shut off all wireless connections, disable most wakelocks and power down any unessential components.
android apps can't turn off wireless connections, android/google has now recently disallowed all apps from controlling wifi on/off . it is up to the user to turn off wifi to save power during standby now.
EvoDroid v1.02 now contains a fix for this issue of numeric gauges and negative values with decimal places. -Hamish.
Maybe you could add here it doesn't support it
http://www.evoscan.com/evoscan-gps-o...flashing-cable
Might look at organising money for an evodroid next month, in stock?
Ok, I went ahead and purchased one. Can't wait to try it out.
I wish it could be used to permantely remove the O2 CEL but it looks like it isn't. I will eventually buy a tactrix cable for this and EvoScan for Windows or OpenECU?
Ok I got my evodroid hooked up and I hooked my AEM Uego to Pin 5 and my Boost to Pin 1 and my Oil Gauge to Pin 2 and when I check the box to enable wide band I get an error message flashing on the screen that says innovate error. I can't figure out what I've done wrong. I'm also getting a very high knock count like anywhere from 185 - 240 that can't be accurate right, because there shouldn't be anyway to get a knock that high I would not think. Could someone help me with these issues?
Oh bummer. But, on the evoscan evodroid start page it says this:
Any idea on why my Knock count is so high? Any why I also I can't seem to get boost or oil pressure gauges to appear on screen, should AEM boost and AEM oil gauges show up? Do I need to download a different template?
Pin_5 Wideband
(Rx Receive) External Serial Input for External Wideband (i.e. serial cable wire from LC1, AEM or ZT2)
Normally you just need to connect the single serial cable wire from the wideband Tx wire and also connect up the black ground wire.. and this will work when you tick the Wideband option on the EvoDroid
sometimes referred to as UART or Serial+5v/-5v.
