Weird Load # at WOT & Stuttering
Old Nov 4, 2012 | 08:02 PM
10isace's Avatar
I'm getting stuttering/hesitation at about 3900 RPM under WOT. It's right around 29psi and up to 32psi that it does this. According to the logging it looks like I'm at 350 load then it goes down to 5 or 1 load. Is this because I may be getting to 360 load and my maps only go up to 350?
I've already adjusted my fuel cut load to 638. It also may be my plugs (about 5k miles on copper plugs).
Old Nov 4, 2012 | 09:17 PM
211Ratsbud's Avatar
whats your 2=1 byte scaling factor?
increase it to 1.5 in the rom and in evoscan perhaps. or greater. like 1.8
Old Nov 4, 2012 | 09:32 PM
10isace's Avatar
It's at 1.4. I'll try 1.5 tomorrow.
Old Nov 5, 2012 | 06:11 AM
evo8426's Avatar
Be sure to set both the one in the tune and the one on evoscan to the same number. The load will show what it is actually supposed to be when you set the number high enough.
Old Nov 5, 2012 | 09:30 AM
10isace's Avatar
Yes, I experienced that a month ago. Makes me wonder WTF I was tuning off of
Old Nov 5, 2012 | 09:57 AM
boosted91t's Avatar
Get iridium plugs.
Old Nov 5, 2012 | 10:36 AM
Boosted Tuning's Avatar
It was just you over running the 1byte factor. Raise it to 1.5 like previously said.
Old Nov 5, 2012 | 05:57 PM
ExViTermini's Avatar
Is it just me or should he order some bearings too?
Old Nov 5, 2012 | 07:48 PM
tscompusa's Avatar
no ****.. that timing is nuts.
Old Nov 5, 2012 | 07:53 PM
211Ratsbud's Avatar
I was thinkin the same
Any updates to the studder?
Old Nov 5, 2012 | 08:05 PM
10isace's Avatar
Am I running a little high on timing?
I'm glad you all pointed it out. I'm lowering my timing as we speak. You can't believe everything you read on the internet! Lessoned learned.
Old Nov 5, 2012 | 08:50 PM
tscompusa's Avatar
yes way to much. evos take less then dsm's.
Old Nov 6, 2012 | 12:16 PM
10isace's Avatar
Lowered the timing by 2* last night. I'll lower more up top thanks to some sound advice from tscompusa.
I raised the 1 byte factor to 1.5 which does show the right load now (360). I'm still experiencing the stutter. I'm changing the plugs now. I'll test tonight. I use NGK BR7ES at .022" gap. I had these in for about 5k miles. The plugs look good/normal. I think I'll gap them to .020". I think 32 psi of boost is causing it to blow out the spark.
Old Nov 6, 2012 | 02:55 PM
Id prolly run bpr8es, but thats me. The e85 cooling may be helping and allowing 7's, have experimented with it yet. Few weeks.
I would do .020 on thr stock ignition at that boost tho
Old Nov 6, 2012 | 06:17 PM
JohnBradley's Avatar
From that log, lowering it 7* globally at high boost wouldnt be a bad idea. 13-14* at 6500 is pretty common bordering on aggressive. You can run a 7 heat range out to 40psi on E85 at 0.020" gap and 630 ft lbs.
Is this on the stock coil dwell settings as well?
Aaron
