MAP Sensor Settings
Old May 15, 2013 | 07:24 AM
Dynotech Tuning's Avatar
So I have tested quite a few Evo 8 Stock MAP sensors now (part#MD305600) and have come to a conclusion. They are either of very poor tolerance from the factory or they tend to drift over the years. Some I have tested read perfect atmospheric pressure and some read MUCH higher (122kpa vs the actual 99kpa). I confirm them with a brand new OMNI 4bar sensor I keep around just for testing. I also checked voltage at the sensor and it is a solid 5.00 volts and the output voltage corresponds with the ADC input I read in Evoscan.
With that said, I don't recommend using a stock MDP sensor for any true logging unless you confirm that it reads your correct atmospheric pressure with the key on/engine off.
This might explain why the evo9 has a different part#.
-Jamie
Old May 19, 2013 | 05:40 PM
So the '03-'04 evos appear to use Delphi PS10078 MAP sensors and the '05-'06 evos use totally different MAP sensors and seem to log differently as well. I'm trying to find data sheets on these sensors to no avail.
Sensor part #'s:
'03-'04: MD305600 (also E1T19172)
'05-'06: MN153281 (also E1T16871)
-Jamie
Old May 20, 2013 | 11:57 AM
todd6027's Avatar
Sensor part #'s:
-Jamie
md 305600 same as jdm evo 7
Old May 20, 2013 | 05:17 PM
Thanks. I found that its actually used in a TON of Mitsubishi's... a ton, lol.
Had about 5 minutes to do a quick comparison between the '03-'04, '05-'-6, and OMNI 4 bar map sensors today just to see how much the two sensors are different at atmospheric pressure.
OMNI 4 bar: 1.19 volts = 101.784 kPa
'03-'04: 4.69 volts
'05-'06: 4.01 volts
Note: OMNI 4 Bar scaling is
5 X (.002421 X [kPa] - .00842)= Output Voltage
((Voltage / 5) + .00842) / .002421 = kPa
-Jamie
Old May 21, 2013 | 06:42 AM
So delphi replied to my email regarding the specs for their PS10078 map sensor that is a direct replacement for the MD305600 sensor found in the '03-'04 evo 8's.
Voltage= .0452 x (Pressure in kPa)+ .330
kPa= (Voltage - .330) / .0452
They haven't given me the usable voltage range of the sensor yet though. So far it doesn't seem to be a good match for the OEM part at all.
-Jamie
Old May 21, 2013 | 02:26 PM
todd6027's Avatar
yes a lot of N/A stuff 4g13/15/ 91/92 no mafs
Old May 22, 2013 | 05:17 PM
-Jamie
Delphi got back to me today and the range of their '03-'04 evo 8 replacement sensor is 15kpa-95kpa (1.000 - 4.625 volts). Clearly not a perfect match for the Mitsubishi MD305600 sensor like they claim.
-Jamie
Old Sep 13, 2024 | 04:09 PM
jeeny007's Avatar
friend i need your help, the map sensor output (kpa) , what is the equation at ecuflash
mrfred
Dec 15, 2022 11:13 AM
mrfred
Feb 26, 2022 06:16 PM
mrfred
Sep 17, 2017 06:11 AM
scheides
Mar 6, 2014 08:09 AM
03whitegsr
Sep 21, 2012 03:54 PM
