Tephra v7 launch How to increase limiter delay?
Old May 12, 2013 | 10:46 AM
kaonashi's Avatar
Ok so my 2step is set at 5500, but the delay is very slow on where the limiter is set. What setting do I need to adjust to decrease the delay between the limiter?
Old May 12, 2013 | 12:26 PM
Raptord's Avatar
What delay are you talking about?
Old May 12, 2013 | 03:01 PM
211Ratsbud's Avatar
The rpm distance cut once the limiter hits? Subies are adjustable normally but the Evo not sure about
Old May 12, 2013 | 03:16 PM
ZanarkO's Avatar
I think he means the time frame inbetween "Pops" lol. Its all in the tune, try playing around abit with the ignition timing remember once it "pops" it goes to a completely different section in the map that more then likelly has higher ignition timing. It really is a skill to tune antilag correctly and so it doesnt bog and etc. Just be carefull not to cook your turbo. when I first did this years ago I had the same issue it would jsut rev up to the limit Pop once fall abit come back up slowely pop once. Trying looking at other peoples maps here.
Old May 12, 2013 | 04:45 PM
kaonashi's Avatar
Yeah, I'm refering to the time it take's it to "Pop" I set my friends & his is about 3x faster then mine is, Can't figure out why the loads are about the same timing isn't that much different.
Old May 12, 2013 | 05:10 PM
foxbat's Avatar
That's true Rats, I never seen it defined in any evo rom version! It would be useful to have it.
Old May 12, 2013 | 05:58 PM
Raptord's Avatar
That's not a setting in tephra, it's how you setup your launch maps that will affect it. That'd be like asking where the 350whp setting is in tephra.
Old May 12, 2013 | 06:14 PM
211Ratsbud's Avatar
Srsly where is that one!
Old May 12, 2013 | 06:53 PM
kaonashi's Avatar
Well I didn't mean so much of a actual "setting" but more less what needed to be adjusted.
It's getting adjusted by the tuner.
peisden
Apr 12, 2015 03:29 AM
mrfred
Nov 22, 2014 02:39 PM
jrz
May 27, 2011 12:00 PM
burnings
50
Aug 19, 2009 06:24 PM
YaroRS
Jul 14, 2009 01:26 PM
