mitsubishi maf 1525a016
Old Aug 7, 2013 | 05:17 AM
jack of all's Avatar
http://item.mobileweb.ebay.com.au/vi...773&cmd=VIDESC
I have been reading about sd, and gm maf and other related things, but I havent found anything or anyone using one of these mitsi maf sensors.
A evo9 afm is too small for my power goals and sd still seems to have issues and complications. The gm maf looks too hard and needs a translator.
I am looking at using a evo9 ecu and ecuflash on a 1g 2.4 hoping to be at 300- 330kwatw therabouts.
Looking at using the 8858 bin or the jdm bin.
This maf has weld on bungs available so some people are using them on something.
Is this maf compatible with ecuflash and any links please? Wiring?
Thanks guys.
Old Aug 7, 2013 | 05:34 AM
AWDBus's Avatar
Just use either the evo 10 (3bar) or Omni 3,4, or 5 bar MAP with a IAT. With what your wanting to do, you will not have any scaling. With the current SD, you will have lots of info and research plus good people to pool from.
Old Aug 7, 2013 | 06:10 AM
Broke4speed's Avatar
Uh, the evo 8 and 9 MAFs are good to 500-ish HP before they start to suck the honeycombs out.
300kw is only 400hp.
Old Aug 7, 2013 | 07:01 AM
Thanks guys.
300awkw is 400 whp for sure. I think that would be better than 500 crank hp if thats where the evo9 afm stops. Its a power sucking auto too. And didnt really want to spring for a afm.
Old Aug 7, 2013 | 05:23 PM
merlin.oz's Avatar
I know for a fact the Evo Karman Vortex MAF is good for 530wkw no problem. Surely thats sufficient capability.
Old Aug 7, 2013 | 06:14 PM
Cheers.
The maf I was refering to seems to be the evo x one.
There is a fair amount of info on here:
https://www.evolutionm.net/forums/ec...ntation-4.html
Thanks for your responses
senate6268
Lancer Engine Management / Tuning Forums
91
Dec 26, 2022 12:20 AM
NZEvox
Feb 10, 2013 01:40 AM
03whitegsr
Sep 21, 2012 03:54 PM
techghost
May 1, 2012 12:41 PM
Done
10
Oct 23, 2009 12:35 PM
