Tephra V7 - Table descriptions??
Old Jan 19, 2014 | 05:21 PM
tsitalon1's Avatar
Maybe I missed it, but is there a doc/pdf/wiki/website that lists all Tephra v7 tables with descriptions of what they actually adjust?
I found Merlins tuning guide, but unfortunately, some of the table names have changed and I believe the advanced fuel controls are missing from that guide.
I have a good handle on most of it, but would like a full reference if available.
So again, if there is anywhere that provides a good description of what each table does, that would be great!!
Old Jan 19, 2014 | 05:39 PM
Raptord's Avatar
The guide linked in my sig goes over many of the boost-related tables.
As far as the rest, there's isn't really a go-to reference with information about all tables, partly because we're still finding out new things about them even now. Best to go through the threads relevant to the tables you're inquiring about and pick out the most up-to-date information yourself I think.
Old Jan 19, 2014 | 06:40 PM
tsitalon1's Avatar
Ok, I guess I can start one with what i know and maybe the community can add to the thread until we get a full table description thread.
I think it will help everyone.
Old Jan 19, 2014 | 07:09 PM
Terror Rising's Avatar
Are you looking for specific table functions beyond what you are already familiar with? If so, post up and people can chime in if they know.
Old Jan 19, 2014 | 09:59 PM
tsitalon1's Avatar
Nothing specific really - I just thought it would be helpful for everyone if we had a single source for table descriptions.
Nothing overly specific - just a one-two sentence description for each table.
Old Jan 21, 2014 | 10:06 AM
tsitalon1's Avatar
I'm 1/3 of the way complete. I'll post up what I know and maybe others can correct my inaccuracies and post info on the tables that I don't have a clue about
Maybe we can make it a sticky....
Old Jan 25, 2014 | 03:50 PM
tsitalon1's Avatar
Here's the start of my contribution, I've listed my understanding of these tables.
Please look over this and correct anything I may have made errors on and add to the ones without explanation.
Hopefully we can get all the table descriptions completed shortly.
Enable/Disable Tephra Mod Options List
Self Explanatory
Knock Light Settings:
KnockSum Required for Slow CEL (Low Knock) – The amount of KnockSum registered to flash the CEL slowly.
KnockSum Required for Fast CEL (High Knock) – The amount of KnockSum registered to flash the CEL quickly.
Load Required for CEL on Knock – The amount of load required for the KNOCK CEL to be armed or ready to flash
High Knock Boost Drop & Knock CEL Flash Time – The amount of time the KNOCK CEL with flash after Knock has ended
Valet Mode Settings
Valet Rev Limit - The rev limit while Valet mode is active
TPS Toggle Time to Activate - The amount of time you must hold throttle at 100% to toggle valet mode on/off
TPS Toggle CEL Flash Time - The amount of time the Valet CEL with flash after Valet mode has been enabled/Disabled
ICS Spray on Knock Settings
KnockSum Required for Spray - The amount of Knock registered to trigger the IC sprayer
Load Required for spray on Knock - The amount of Load registered to arm the IC sprayer
No-Lift-to-Shift Settings
NLTS RPM Drop - At the moment the clutch is pressed and NLTS activates, the ECU sets a rev limiter at the current RPM - this RPM drop value. For example, if you press the clutch at 7000 RPM and RPM Drop is 800, the rev limiter will be set to 6200.
NLTS TPS Threshold - Minimum TPS for NLTS to be allowed to activate when the clutch is pressed
NLTS Speed Threshold - Minimum speed for NLTS to be allowed to activate when the clutch is pressed
NLTS Load Threshold - Minimum load for NLTS to be allowed to activate when the clutch is pressed
AFR Safety Monitoring Settings
AFR Safety Load Threshold – The amount of load registered must exceed this value for the AFR safety system to be armed.
AFR Safety Max AFR (volts) – Raw WB02input voltage must exceed this voltage to trigger the AFR Safety system
AFR Safety Boost Drop and CEL Flash Time – The amount of time the WGDC will drop to 0%
AFR Safety Detection Period – The amount of time the Raw WB02 input voltage must exceed target voltage before arming the AFR Safety System.
Miscellaneous Tephra Mods
2byte to 1byte load factor – The multiplication factor used for calculating & logging 1byte load in EvoScan – Must match Evoscan.
Manual ICS Linger Time – The amount of time the IC sprayer sprays AFTER the ICS button is pressed and released
Alt Map Activation Settings
Alternate Map Time to Activate – The amount of time delay before ALT Maps are enabled after being triggered
Alternate Map Load Threshold – The calculated load must be BELOW this value for ALT MAPS availability.
Alternate Map ADC0F Threshold - ?
Alternate Map Ignition Settings
Alternate Hi Octane Ignition Map – The timing tables used when in ALT MAP mode
Alternate Map Fuel Settings
Alternate Hi Octane Fuel Map – The fuel tables used when in ALT MAP mode
Alternate Injector Scaling – The injector scaling used tables used when in ALT MAP mode
Alternate Cranking Enrichment IPW Adder (Main) – The injector enrichment used for starting the car when in ALT MAP mode
Alternate Map Boost Control Settings
Alternate Boost Wastegate Duty – The wastegate duty cycle used for ECU Boost control when in ALT MAP mode.
Alternate Boost Desired Engine Load – The load target the ECU will try to maintain in ALT MAP Mode IF Boost control is using load for error correction
Boost Desired Engine PSI – The PSI target the ECU will try to maintain in ALT MAP Mode IF Boost control is using PSI for error correction
Global Fuel Settings
Fuel Cut Multiplier - Allows you to choose whether you want to use the Fuel Cut Load X1 table or Fuel Cut Load X2 table for your fuel cut.
Fuel Cut Load X1 - Allows input of the fuel cut load values for varied RPM. If load exceeds these values for a given RPM, fuel cut will be activated to protect from an overboost.
ST Fuel Max Trim - ?
ST Fuel Min Trim - ?
Maf Scaling (MAF Adder already included) - Used to scale your MAF signal – mostly used when an aftermarket intake/filter has been installed
Fuel Cut Load X2 - Allows input of larger fuel cut load values. Values here will be double of the ones in the 1X table.
Fuel Cut Load Trigger Delay – The amount of time the load must exceed Fuel Cut Load setting before Fuel Cut is activated
Injector battery Voltage Latency Comp – The amount of time is takes the ECU to fire the injectors at a given voltage – This must be adjusted for your injectors, it is critical that these settings are correct. Log your fuel trims (Mostly LTFT Low) to ensure this is correct
Map Compensation - ?
Relative Air Density vs Temp for Airflow/Hz - ?
Airflow/HZ Baro and Air Temp Comp - ?
Maf Sensor Filtering - ?
Maf Size - ?
Open Loop Load #1 – The amount of load needed at a given RPM to initiate Open Loop Mode during warm up
Open Loop Load #2 - The amount of load needed at a given RPM to initiate Open Loop Mode during normal operation
Open Loop Throttle #1 - The amount of throttle needed at a given RPM to initiate Open Loop Mode during warm up
Open Loop Throttle # 2 - The amount of throttle needed at a given RPM to initiate Open Loop Mode during normal operation
Global Boost control Settings
Boost Error Correction (Load) – When using Load based boost error correction, this is the amount of correction at a given load deviation
Boost Error Correction (PSI) – When using PSI based boost error correction, this is the amount of correction at a given PSI deviation
WGDC=100% under this load – Wastegate Duty cycle will stay at 100% BELOW this calculated load
RPM/Speed to Gear – This is the table used to let the ECU know which gear it is in. – Mostly used for Gear Dependant Boost Control
MAF IAT WGDC Correction - Adjusts the base WGDC depending on IAT.
TPS WGDC Correction - Adjusts the base WGDC depending on TPS.
WGDC Correction Interval (High Gear Range) – How quickly the ECU will monitor and respond to boost (load or PSI) target vs actual deviation in High Gear
WGDC Correction Interval (Low Gear Range) – How quickly the ECU will monitor and respond to boost (load or PSI) target vs actual deviation in low Gears
Max Total Upward WGDC Correction vs TPS – The maximum amount the ECU will INCREASE boost when actual boost LESS than Target.
Max Total Downward WGDC Correction – The maximum amount the ECU will DECREASE boost when actual boost is MORE than the target
Max WGDC vs Coolant Temp – The maximum WGDC the ECU will allow at a given coolant temperature
WGDC Limit During Fault - ?
Boost Control High/Low Gear Range RPM/MPH - ?
Minimum Load for Boost Control – The ECU will not attempt to control boost until calculated boost EXCEEDS this value.
BCS Re/De-Activation RPM - ?
Global Boost Control Type
Variable for Boost Control – Enter “0x6B48” for Load based or “0x6AEC” for PSI based boost control
SHLR ->SHLL for EBC – Enter “0x4A01” for Load based or “0x4A00” for PSI based boost control
Boost Error RAM Address – Enter “0x69CA” for Load based or “0x6EE2” for PSI based boost control
Boost Error Ram Address in Load Error – Enter “0x69CA” for Load based or “0x6EE2” for PSI based boost control
MUT8A – Enter “0x6ACD” for Load based or “0x6EE3” for PSI Based boost control
MUT8B – Enter “0x6B41” for Load based or “0x6EE9” for PSI based boost control
Global Launch Maps
Launch Hi Octane Fuel Map – This is the open loop fuel map used when the vehicle is in launch mode
Launch Hi Octane Ignition Map - This is the open loop ignition map used when the vehicle is in launch mode.
Launch Map TPS Threshold – Throttle Position must exceed this value to activate launch mode.
Launch Map Speed Threshold – Vehicle speed must be lower than this value to activate launch mode.
Main Map Ignition Settings
High Octane Ignition Map – The Primary ignition table used when at normal operating temperature during open loop operation (mostly at WOT)
Low Octane Ignition Map - The Primary ignition table used when at normal operating temperature during open loop operation AND Low Octane has been detected due to excessive knock history (mostly at WOT) – Caution, ECU can interpolate between Hi and Low Octane tables – tune accordingly
Ignition Charge Time - ?
Ignition Coil Charge Time - ?
Ignition Coil Charge Time 2 - ?
Main Map Fuel Settings
Injector Cranking Enrichment IPW Adder (main) – Additional IPW used to start the car per coolant temperature.
High Octane Fuel Map - The Primary fuel table used when at normal operating temperature during open loop operation (mostly at WOT)
Low Octane Fuel Map - The Primary fuel table used when at normal operating temperature during open loop operation AND Low Octane has been detected due to excessive knock history (mostly at WOT) – Caution, ECU can interpolate between Hi and Low Octane tables – tune accordingly
Max Rich AFR vs Coolant - ?
Injector Size Scaling – The value used to compensate for larger injectors while using your Primary Map.
Closed Loop Min Coolant Temp – The temperature at which the ECU will transition to Closed loop mode – Under this temp, ECU will remain in Open loop.
Old Jan 25, 2014 | 05:30 PM
Raptord's Avatar
Self Explanatory
Valet Mode Settings
Maf Size - ?
Global Launch Maps
Filled some of them in. TBH though I've always found that the vast majority of table names were pretty self explanatory as far as what the tables do.
Old Jan 25, 2014 | 06:57 PM
tsitalon1's Avatar
Thank you for your additions!
Your right, there are a lot that is self explanatory. However some are most certainly not, especially when you get into advanced fuel controls...
Having a single thread with a brief description of each table will get people going in the right direction, or at least I hope it will
More to come when I have time...
Old Jan 27, 2014 | 05:32 PM
ST Fuel Max Trim - Maximum addition to fuel trim by temperature.
ST Fuel Min Trim - Maximum removal of fuel trim by temperature.
Relative Air Density vs. Temp for Airflow/Hz - The varying air densities by temperature for the MAF to determine oxygen content.
BCS Re/De-Activation RPM - Turns the BCS off below "Reactivation Off", turns it on above "Reactivation On". Assume it deactivates at 7500 RPM, which would need to be changed for high RPM engines.
Old Jan 27, 2014 | 07:53 PM
211Ratsbud's Avatar
I agree here. Research is part of the process here..
While this general information above may hold true, just between 8858 and 8859 different table names exist especially for more recent developed stuff. I've compiled my best organization of 8858 definitions and had ambition to do 8859 but lost it. It might be worth your while to group your XML so that tables are more readily grouped and available, after that appearant correlations will be easier to see .
This thread will surely give people with green fingers a greater chance at succeeding easier
Old Apr 16, 2014 | 12:58 AM
Nimpoc's Avatar
Thanks for starting this Tsi. It'd be awesome to get someone to update EcuFlash such that it'd be able to read this info and present it as Tool-tips within the app. Embedding the notes in the defs.xml would make it file specific.
Along these lines it'd be super great to see if Merlin would open up his Tuning Guide so it could be posted as a Wiki and maintained by the community. That way we'd have a quick unified reference rather than having to dredge the forums for that one thing you read so long ago late that one night... Capping it all would be to tie the Wiki back into EcuFlash as the help system content.
Hardware guys waving his software hands in the air again. I'd be happy to do some editing of the Tuning Guide. I've already got a bunch of notes on my printed copy.
Old Apr 17, 2014 | 11:06 AM
todd6027's Avatar
Alt maps ADCOF threshold =To Activate Alt Maps, ADC0F Voltage Input Must Exceed this value
Old Aug 20, 2014 | 03:00 PM
osetsky's Avatar
For those who just got a tactrix cable this is all gold.
DormantBeast
13
Jul 9, 2017 07:38 AM
Raceghost
Jul 29, 2016 12:04 PM
onefast2gdsm
May 1, 2016 12:23 AM
enash99
Jun 20, 2011 10:34 AM
phenem
Nov 7, 2010 05:26 AM
