U0121 fault
Old May 9, 2014 | 02:13 PM
1sxyrxy's Avatar
U0121 fault
hello, i currently have a lancer, that i put a turbo on. i currently have a evox ecu installed to get my mivec working again. now i have a fault for the AWD system, i know people have gotten rid of this fault but nobody can give me a answer on how they did it on the lancer forums. i was wondering if there is way i could modify the xml file and get the ecu to ignore this fault. i am using rom 52680022 any help will be greatly appreciated.
Old May 12, 2014 | 06:40 PM
lancer2008's Avatar
re
Im in the same boat with you. I believe you need to take it to dealership and have them use MUTIII tool to disable ASC. I also believe that evo x rom is setup for ASC which means it probably disables ABS, since you can have either or only.
If you find a solution def let me know.
Old Jan 2, 2015 | 11:38 AM
sebass007's Avatar
See: https://www.evolutionm.net/forums/la...na-lancer.html
RA11226
Evo X How Tos / Installations
120
Jun 24, 2022 03:19 AM
Black9
12
Aug 19, 2018 12:01 PM
metallman
Apr 14, 2017 08:25 AM
Razorb0iz
Sep 15, 2012 08:33 AM
veszett
Jan 24, 2010 07:14 PM
