MD346675 swap woes
Old May 12, 2014 | 03:13 PM
Dbisk87's Avatar
MD346675 swap woes
Hello, I am currently swapping my 97 eclipse gsx over to an MD346675 ecm. I connected the reflash connector off my openport 2.0 into pin 79 and everytime I try to read the rom using ecuflash I get init sequence 2 than an error pops up. I am using 1.43. The openport connector shows up in ecuflash and I also have voltage at pin 79 when it attempts to flash. I also tried using evoscan to verify it wasn't an ecuflash error and it gives me the error less than 5v detected. I've checked my fuses and I also have a battery charger hooked up while trying to do all this with a voltage of around 13.5v so definitely not a power issue. I cannot even get my autotap code reader to connect to the new ecm and I am starting to wonder if my md346675 is dead. Any input would be great because this is getting to be frustrating . Thanks for your time!
Old May 12, 2014 | 03:38 PM
Dbisk87's Avatar
Confirmed the ecu definitely works so we can rule out dead ecu!
Old May 12, 2014 | 03:56 PM
irwintan27's Avatar
Wrong thread lol
Old May 16, 2014 | 05:46 PM
Dbisk87's Avatar
Ended up being a lose connection on pin 16 of my obd2 port. My voltmeter probe was able to reach the pin but not the openport cable. Evoscan and ecuflash working flawless!!!!
deeman101
Mar 3, 2021 07:56 AM
Mad_SB
14
Oct 4, 2017 04:08 AM
evoscan
52
Jun 20, 2017 01:46 AM
voltexct9a
Jan 22, 2016 05:23 PM
mmixan
Sep 17, 2011 04:29 PM
