MUT Request ICS
Old Jun 1, 2014 | 01:01 PM
jeffbeagley's Avatar
MUT Request ICS
Trying to find the mut request for the Intercooler Sprayer switch for 9653. I tried using 060B per the wiki and it logged a 2.x something and never changed. I tried logging the default value for altmaps at requestid 40 but it only logs 6 without change.
Any ideas? I'm trying to set this up as my trigger for logging if possible. I was going to use the AC switch since I don't have AC anymore but even with the switch turned off it jumps between 1/0 for some reason.
Thanks for the help!
Old Jun 1, 2014 | 01:26 PM
Now that I think about it, would it be possible to re-wire my AC switch into ADC0F input and set it up with a MUT request and use that as the trigger?
Old Jun 3, 2014 | 08:02 AM
mrfred's Avatar
could you explain in more detail what you are trying to do?
Old Jun 4, 2014 | 05:57 AM
I'm using the Tactrix 2.0 SD Card logging feature. So instead of having it log all the time, I want it to be triggered through a requestID that you can log. At first I figured the AC switch would be easy to log, enabling it as a trigger, and thus being able to click my AC button to start logging to the SD Card. However I found spotchy performance when logging it via Evoscan, it seemed to fluctuate often between 1/0.
So I'm curious what other options I have on setting up a logging button. I figured maybe I can re-wire the AC button on a relay with a resister and wire it into a 5v input on the ECU, set that up to where I can log the voltage.. then apply a trigger to the Tactrix so it'll start on >~3v for instance.
Old Jun 4, 2014 | 08:28 AM
mrfred's Avatar
A/C button will do it. Just need the correct item to log. Remind me later today, and I'll post up the correct MUT request to use.
Old Jun 4, 2014 | 04:02 PM
Word!
I logged the default parameters in Evoscan for the AC Switch but it was fluctuating between 1/0 not by using the switch. So likely it was the wrong one.. or who knows. Unfortunately I changed the request ID in Evoscan so I don't remember what I was originally logging, should have had notes!
Old Jun 4, 2014 | 06:41 PM
mrfred's Avatar
Word!
Turns out I'm a fail on this. There is a way to track when the A/C compressor is turned on, but this won't be helpful because the compressor is automatically disabled during agressive driving. I was hoping I'd find a flag that tracks when the A/C system has been enabled, but no luck there. It might exist, but its not something I can find easily.
One extra tidbit - the EvoScan items relating to A/C operation are totally wrong.
Old Jun 4, 2014 | 10:00 PM
Haha word, I appreciate you looking into it. I suppose this leaves me with my other option, rewiring the switch into a relay then into a 5v input on the ECU. Believe I still have fuel temp pin available to use. Although, if I have to do that much work.. I might as well just leave it logging all the time lol.
mrfred
Jul 20, 2016 06:02 PM
jchang
Jun 17, 2016 09:04 AM
SnailSpeed
Dec 13, 2015 04:31 PM
Dynotech Tuning
Feb 13, 2012 09:19 PM
bleunetizen
Feb 22, 2011 06:11 AM
