52680017 rom boost control problems
Old Sep 10, 2014 | 07:49 AM
got boost??'s Avatar
Hi guys,
Probably this have been covered before but trust me, i searched and found nothing.
i need some help with boost control on 52680017 rom (inherits from 52680015). I enabled mode23 logging so i get nice log readings. The problem is when i try to control boost. it keeps spiking up to 2 bar and holding at least 1.8 to redline (readings on a boost gauge).
Theese are the tables i get with my rom:
I even tried lowering duty cycles and boost targets to zero! and does the same thing!
I double checked solenoid connections so no problem down there.
Seems theres no effect when changing values on any table!
Am i missing something?
Regards.
Old Sep 12, 2014 | 06:16 AM
come on!! no one????
Old Sep 12, 2014 | 08:49 AM
franzcars's Avatar
Could you post the stock ROM and XML you're using. Could be that its improperly defined and you're not changing anything
Old Sep 12, 2014 | 11:52 AM
Sure.
XML
http://www.datafilehost.com/d/6f8537fc
Rom
http://www.datafilehost.com/d/adc98052
to download, uncheck box "Use our download manager and get recommended downloads" and you'll get a download button.
Internal ID is 52680017 but inherits from 52680015
Regards.
Old Sep 12, 2014 | 12:10 PM
10isace's Avatar
What's up got boost??
I looked at your rom. I see this when the boost controller is not hooked up right. Do you have a 3 port or stock? Hoses could have gotten crossed by accident. Post up a log of a pull with the 2 bar spike.
Old Sep 12, 2014 | 12:34 PM
Nope, stock boost solenoid. Hose being crossed is very possibly cause someone messed up there before.
I'll check that first and post a log.
Regards.
mrfred
Feb 26, 2022 06:16 PM
jakgal04
Sep 20, 2017 08:09 PM
mrfred
Sep 17, 2017 06:11 AM
mplspilot
Dec 5, 2016 03:29 PM
tsitalon1
38
Oct 12, 2010 08:45 AM
