Altering one table changes another?
Old Nov 12, 2014 | 07:17 PM
Tuxevo's Avatar
In an effort to get the ecu to stop pulling timing where it's not suppose to, I've been going through and zeroing out the low coolant timing trim tables in the high load areas. When I went to do this to the low coolant timing trim map 2 (I labeled it group 1) it changed the rpm scaling in the accel enrichment (incorrect) table (labeled group 2 in the second picture.
Since I wasn't sure what effect this would have, I tried to figure out a solution that would take the timing changes away, without altering other tables. What I did was rescale the load axis with values that would likely never be seen. pictured here:
Thoughts on this would be appreciated and better still would be an explaination of how the timing table factors in and why the accel enrichment table is labeled "incorrect".
Old Nov 13, 2014 | 11:46 AM
Raptord's Avatar
I think this just shows that the accel enrichment table is indeed "incorrect"
The reason changing one is affecting the other is because you're changing some bits that are being read by both of those tables. In this case one of these is clearly wrong, most likely the accel enrich table.
Old Nov 25, 2014 | 08:00 AM
mrfred's Avatar
yeah, one or both of those tables has incorrect addresses.
Hiboost
Jun 27, 2009 12:04 AM
Kierkegaard
Jul 15, 2008 03:05 PM
blackonblackevo
Jul 20, 2007 04:35 PM
MrMejia
Sep 11, 2005 05:57 AM
evo55
Oct 1, 2004 04:14 PM
