another unknown rom image 2008 evo x
Old Jun 5, 2015 | 01:21 PM
  #31
nomad's Avatar
Originally Posted by MikeyPSF
I'm guessing you mean you're seeing an error not 'crashing' as in the program is shutting down. Is that right? I'm getting ready to head out of the office so I might be able to look at it until Monday, but can you try a test write and when you encounter the error, copy everything from top to bottom in the EcuFlash 'Task Info' logging window, and paste that in an email sent to support at tactrix dot com? If you aren't able to complete a test write then don't try a real write.
yes shutting down, I will try and get that info.
Old Jul 7, 2015 | 09:10 AM
  #32
MikeyPSF's Avatar
Are you using the most current version from our site? That would be 1.44.4503. If you are using the latest version, what version of Windows are you using? 32 or 64 bit? Can you repeat the crash by doing a particular action?
-Mike
Tactrix
Old Jul 8, 2015 | 06:16 AM
  #33
nomad's Avatar
-Mike
Tactrix
Yes it's all updated and the problem is fixed
Thanks
Old Jul 8, 2015 | 09:05 AM
  #34
MikeyPSF's Avatar
Thanks for the update. I was actually posting in reply to someone who posted after you but he seems to have deleted his post. Problems solved all around!
-Mike
Old May 21, 2021 | 12:09 AM
  #35
Christinmcni's Avatar
I am also having issues reading my rom with ecu flash it says its unknown. The car has been tuned before I don't know if that's why buti tried to find the ecu ID with the saved .bin file and can't find it at all. Could someone give me a hand? I will post the file tomorrow.
Old May 21, 2021 | 07:51 PM
  #36
here is what my rom is coming up as.
File Type: bin
Old May 23, 2021 | 09:44 AM
  #37
GeoMitsu's Avatar
Definition file attached.
save it to : C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
P.S: The file is barely tuned ...
File Type: xml
GregorEST
Lancer Engine Management / Tuning Forums
Oct 11, 2024 05:46 AM
Jamspack
Nov 15, 2020 07:06 PM
Miguel Ortega
May 14, 2019 01:31 PM
EatSleepBoost
May 18, 2011 05:13 PM
adcgn45
Dec 22, 2009 06:41 PM
