Flex Fuel testing in TephraXMOD V3
Old Apr 4, 2016 | 01:53 PM
  #181
tephra's Avatar
Originally Posted by Shinzon
ant support for 56590006? Usdm 2015 MR
Would run 56590005..so yes
Old Apr 5, 2016 | 05:02 AM
  #182
Beeble's Avatar
Originally Posted by gsxrmel
Attachment 250139
Attachment 250140
thanks beeble, with this xml i have 2 sst tables references it is correct? and also have a ommipower 4 bar sensor dates can i use this xml with the stock map sensor
regards
yes it has bits of everything there so some sst tables will repeat. it was some old development stuff .
there will be Omni 4bar and also normal 3bar tables there to use
Old Apr 5, 2016 | 06:43 AM
  #183
gsxrmel's Avatar
and i need to tuning the two bits of sst ?
Old Apr 5, 2016 | 02:47 PM
  #184
Beeble's Avatar
^^ the second sst section has pretty much everything you need
the top sst section, development - you can ignore most of it
Old Apr 6, 2016 | 12:18 AM
  #185
gsxrmel's Avatar
at this moment im with the 53050009 it is bether to go with the 53050012?
regards!
Old Apr 6, 2016 | 12:31 AM
  #186
Beeble's Avatar
He's only made 53050012 so yes
but like you I always use 0009.
However V3 was made on 0012 , so that is that!
Old Apr 7, 2016 | 02:03 AM
  #187
SaaX's Avatar
Hi Tephra.
it is avaliable the v3 for 56920008?
Old Apr 12, 2016 | 03:15 AM
  #188
EvoXEmma's Avatar
Lightbulb
Originally Posted by SaaX
Hi Tephra.
Coming soon, see further up in this thread.
Waiting desperately for this as well...
Old Apr 30, 2016 | 08:14 PM
  #189
tephra's Avatar
good news.
2012 USDM GSR (58010005) and 2009 USDM RA (53600010) are in the final stages of testing.. so they will be up soon..
2010 USDM GSR (55570006) is also ready for testing...
today i'm going to try and get 56920008 going as well but for now i need a rest, my brain hurts
Old Apr 30, 2016 | 10:23 PM
  #190
Zash's Avatar
Originally Posted by tephra
good news.
No resting dude
Get on to that AUDM MY11+ MR please ...... Then you can rest your brain all you like and I'll even help with a few of these.....
Old May 1, 2016 | 01:57 AM
  #191
tephra's Avatar
OK I just did 56920008, im waiting for confirmation it works before letting people order it
Old May 1, 2016 | 11:00 PM
  #192
XBlueOctane's Avatar
Any plan to make my 2011 GSR (56890013) available? Or is there an alternative compatible file? I have tephra v2 currently. Thanks
Old May 2, 2016 | 02:39 AM
  #193
psfp's Avatar
It's already available: http://www.tephra.it/v3/
Old May 2, 2016 | 05:36 AM
  #194
tephra's Avatar
I have several in test at the moment (see www.tephra.it/v3 for info).
I will be adding USDM 2008-2009 MR (52690022), and some JDM ROM, but i'm not exactly sure which one because for some reason JDM ROMID's confuse me
otherwise I am taking requests for ROM's...
Old May 2, 2016 | 05:46 AM
  #195
psfp's Avatar
Hi Tephra! What is 57140003's position in your queue?
