Flex Fuel testing in TephraXMOD V3
Old Dec 2, 2015 | 05:21 AM
  #76
hispanicpanic's Avatar
Originally Posted by tephra
no its not...
i have results coming today for the CANBUS integration - if it signed off, then...
well how did it go
Old Dec 4, 2015 | 07:23 AM
  #77
jracer's Avatar
I finally have all my parts to go flex fuel !! Can't wait for it to go public !
My parts list ....
ID1000 injectors
ANSU 330 fuel pump
GM flex fuel sensor
Flexconverter/Bluetooth cable
A old Android phone for the flex fuel App.
Old Dec 8, 2015 | 06:01 PM
  #78
Wanchai Panpron's Avatar
HI All
Did you know that Lancer Thailand 4B10 1.8 is FFV car.
There is no ethanol sensor fit on it , but ECU can read % Ethanol .
I don't know how ECU calculate Ethanol.
You can check with the stock ROM.
I have read many topics on this site to learn about how to flash ECU for Asian Lancer.( Thai,Malay,China,Singapore ) for a month.
I tried to create XML for read Asian stock rom on ECUflash.
But it not work till now.
I found ECU flash can not read the Asian stock rom.
Due to the ECU address of in not on 5002a , It different form
The file size is not
the different of Lancer Asian ROM and Other Lancer Rom as below.
1.ROM File size
Asian (Thai,Malay)= 1,050,605 bytes
Other(JDM,US) = 1,048,5XX bytes
2.ECU ID Address
Asian (Thai,Malay) =50300,50360,etc.
Other(JDM,US) = 5002a
The XML detail that i was tried as below, It is not working.
ECU ID
50xxx
ECU ID
mitsucan
M32186F8mitsucan
All rom after 2006 + except Asian ROM are available to open with ECU flash with this XML detal just open not table.
But Asian ROMs are unknow .
I don't know what was i wrong .
checksummodule ?
memmodel ?
internalidaddress ?
I can make XML to open All Rom of Lancer/Evo 2008+ , except Asian ROM
Why ?????????????
Help me please .
Can some one please help ?
File Type: bin
Old Dec 8, 2015 | 07:28 PM
  #79
kaganader2's Avatar
Registered User
Originally Posted by Wanchai Panpron
HI All
I have read many topics on this site to learn about how to flash ECU for Asian Lancer.( Thai,Malay,China,Singapore ) for one mount.
1.ROM File size
2.ECU ID Address
ECU ID
50xxx
ECU ID
mitsucan
M32186F8mitsucan
checksummodule ?
memmodel ?
internalidaddress ?
Why ?????????????
Help me please .
RomID is 54980003 @ address 50367, which is odd as that is a 2.4 GTS Rom ID used in China. But in the 2.4 GTS Rom the address is at 5002a while in this rom it is at the address 50367
I've never dissembled and defined a thailand rom before
Old Dec 8, 2015 | 07:41 PM
  #80
Thank you very very much kaganader2.
I did it wrong for long and no one answer me.
You are kindness
Best Regards
Old Dec 8, 2015 | 08:22 PM
  #81
I have tried with XML as below detail.
ECU Flash still unknown Asian Rom.
xmlid = 54980003
internalidaddress = 50367
internalidhex = 54980003
flashmethod = mitsucan
memmodel = M32186F8
checksummodule = mitsucan
I think memmodel M32186F8 can not read this Rom.
Old Dec 8, 2015 | 08:40 PM
  #82
kaganader2's Avatar
Registered User
double post
Old Dec 8, 2015 | 08:43 PM
  #83
kaganader2's Avatar
Registered User
xmlid = 54980003
memmodel = M32186F8
That all seems to be correct
xmlid= 54980003
internalidaddress= 50367
internalidhex= 54980003
make= Mitsubishi
market= USDM
model= Lancer
submodel= Basic
transmission= mt
year= 2008
flashmethod= mitsucan
memmodel= M32186F8
checksummodule= mitsucan
It should be able to start making your xml definition file from the values you have. I know if you have ecuflash open you will have to close and re open Ecuflash to read the newer xml files in its rom meta folder.
Old Dec 8, 2015 | 08:50 PM
  #84
You mean you are able to open the rom by Ecuflash form your site ?
But i can not , I will try again.
Old Dec 8, 2015 | 09:39 PM
  #85
RazorLab's Avatar
Most of the modern FlexFuel cars do the interpolation off fuel trims instead of an actual ethanol sensor because it's lower cost and less failure rate.
Works fine for non performance vehicles.
Old Dec 9, 2015 | 01:56 AM
  #86
xmlid= 54980003
make= Mitsubishi
market= USDM
model= Lancer
submodel= Basic
transmission= mt
year= 2008
memmodel= M32186F8
I have done with a new rom file. ( I downloaded form stock rom that share at evosacn )
The files uploaded above are error. it is bad file. i wll deleted it.
The good file has size 1,048,576 byte.
Ecuflash can read it.
To all newbie for Ecuflash.
Please check size of rom file that you pull form site and use to learn Ecuflash.
File for lancer/evo 2008+ shall about 1,048,576 byte.
If the file is over 1,048,576 , don't use it.
below it Lancer TDM 1.8 FFV CVT.
It is OEM FFV stock ROM.
ECU ID locate at 5002e.
Old Dec 9, 2015 | 07:59 AM
  #87
kaganader2's Avatar
Registered User
Yup this is correct. 05+ GM cars do it off of the o2 sensor, basically a virtual flex fuel (off of o2 reading and fuel trim) instead of a physical reading.
Old Dec 20, 2015 | 07:35 AM
  #88
jracer's Avatar
When going public ??
Old Dec 22, 2015 | 11:28 AM
  #89
jracer's Avatar
Have all my parts for FlexFuel .. Just waiting for
It to go public
Old Dec 25, 2015 | 07:25 PM
  #90
tephra's Avatar
a few xmas presents being delivered today...
